weird bogging problem
Old Jun 22, 2007 | 06:47 AM
_Endless_'s Avatar
Default weird bogging problem
bone stock internals b16 engine with garrett t3/t4 turbo boosting 6psi. i'm using uberdata for engine management.
this is what i'm noticing...when i first started the engine while it's cold, the drive will be fine and normal. but if i shut off the engine, say while buying something and then i restarted the engine and drive at low rpm, the engine would bog down hard when i lift off the gas pedal at around 2k rpm even without stepping on the clutch and it will jerk forward once i step(lightly) on the gas pedal again.
it is very irritating already even if i had a/c switched ON but the problem will fade away after few minutes of driving. it doesn't do this when the engine was first started from cold. any idea what's causing this?
WojtekG
Sep 13, 2018 07:15 AM
precision4
May 26, 2007 10:48 PM
