Turbonetics Ball Bearing 62-1
Does anyone have expierience with this turbo? I have one that im going to use on my 84x89 build up. Any numbers? Im planning on making 500whp with this turbo and i was just wondering if anyone has had good results.
Turbonetics 62-1 BB big shaft s housing 70a/r cold 63a/r hot.
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">The turbo is supposed to make 10% more hp then the 60-1. Does anyone have expierience with a 60-1?</TD></TR></TABLE>
No, nobody here has ever used a 60-1 . . . . have you searched? I've seen millions of 60-1 turbo setups on here over the years.
liam
liam
Munkyw3rkz.webs.com
1 Post
Re: (92redhatch)
yes i had this turbo on my Ls-T.. LOVED it....
my homie had it as well on his LsVtec... he went 10.80's in it made 500 something whp......
the person who got my 62-1 pu tit on a Lsvtec back east an dif irememebr correctly it went low 11's on BFG's
was it a ball bearing turbo? because before i took apart my car i had my ball bearing 62-1 on my b16 for a day and i had full boost at 5000rpm.
Munkyw3rkz.webs.com
1 Post
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">was it a ball bearing turbo? because before i took apart my car i had my ball bearing 62-1 on my b16 for a day and i had full boost at 5000rpm.</TD></TR></TABLE>
yes mine was.. but the 2.0L 9:1 comp helped it a lil
Munkyw3rkz.webs.com
1 Post
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">ya thats what im doing now a 2.0l erl block 9:1 compression. I want to see how much power i will make. the goal is 500whp.</TD></TR></TABLE>
you will make that easy!!! homie made 580 on GSR head with GSR cams with a 8:5 comp block
I made 480@20psi on a 60-1 .63ar
and 517@32psi on the same setup the turbo runs out of juice and destroys itself anything over 25psi so be careful!
Munkyw3rkz.webs.com
1 Post
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">how much boost? you got a dyno sheet?</TD></TR></TABLE>
i dont but im might be able to get it... that was at about 25psi if i remember right
i think after 20 psi the turbo isn't efficient. i should be able to make 500whp before 20 psi. i dont have experience with the turbo yet but from what i hear thats what it sounds like.
boostin b16
04-17-2003 02:31 PM
