Is this bottom end good enough to hold 400whp?
I'm thinking about buying a block with these internals. Is this good to hold 400 whp? I think it would be ok, I just wanted to get other peoples opinions. Thanks Ramsey.
b18b block
81.5 mm je 9/1 pistons
eagle 650 hp rods
acl main and rod bearings
golden eagle block gaurd
type r oil pump
arp head studs
b18b block
eagle 650 hp rods
type r oil pump
arp head studs
Re: Is this bottom end good enough to hold 400whp? (Rooftop voter)
with a good tune it should hold no problem.
but remember, there are a lot of variable that can go wrong, if a part fails, bad things can happen!
I rocked pretty much the same setup (minus blockguard) for over a year no problems.......350-400 whp daily driven.
Man U FTW
Re: (Rooftop voter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rooftop voter »</TD></TR><TR><TD CLASS="quote">What exactly does the block guard do? I've heard it helps, then I've heard it doesn't really do anything at all?</TD></TR></TABLE>
it keeps the sleeves from rocking back and forth....it also adds a little bit of strength to the top 1/2" of the sleeve
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">
it keeps the sleeves from rocking back and forth....it also adds a little bit of strength to the top 1/2" of the sleeve</TD></TR></TABLE>
i asked my machine shop guy the other day when i went to pick up a spare lsv-r motor about block guards. i have read numerous posts here of people pushing maddd power without the use of a bg. i asked what his thoughts are, and he said that he reccomends the bg. he also told me that they have never gotten a cracked sleve yet from they way they install the bg. what are your guys thoghts on bg's? how come you guys who are pushing around 3-400 hp on stock sleeves choosing NOT to go with a bg? im very curious, as i am contemplating on what to do.... either going stock sleeves with no bg, stock sleeves with bg, or sleeved. sorry for the thread jack btw
Re: Is this bottom end good enough to hold 400whp? (GetawayInMoscow)
block gaurd gets you home after the sleeve starts cracking. haha, i found that out first hand sorta.
i was also curious about block gaurds, i just got a deal on a built motor that has one professionally installed and i hear alot about people who dont like them or say they would never run them. i kind of figured that if a rep-ed company makes them they cant be that bad. when i searched i heard that some have over heating issues, im curious to why or what are the down sides to them? not trying to thread jack
Re: (turbo_ls_69)
bump for some bg infos... pros and cons to y u would or would not use a bg for your 300-400 hp setup. i understand that alot of u guys are saying its not neccessary, but lets say just for piece of mind without the option of sleeving... would it be worth the $100?
Modified by bnut510 at 2:25 PM 6/21/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rooftop voter »</TD></TR><TR><TD CLASS="quote">I'm thinking about buying a block with these internals. Is this good to hold 400 whp? I think it would be ok, I just wanted to get other peoples opinions. Thanks Ramsey.
b18b block
eagle 650 hp rods
type r oil pump
arp head studs</TD></TR></TABLE>
VERY CAPABLE as long as everything is in good working order and use a good tuna
b18b block
eagle 650 hp rods
type r oil pump
hpc.aeroe.
06-21-2010 08:53 PM
b18sihatch
07-12-2006 12:51 PM
