? mapsensor
Old Jun 24, 2007 | 08:32 AM
nihad's Avatar
Default ? mapsensor
What should i use for my obd0 civic hatch a missing link or get a gm bar mapsensor.
Old Jun 24, 2007 | 08:49 AM
Boostfed's Avatar
New User
Default Re: ? mapsensor (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">What should i use for my obd0 civic hatch a missing link or get a gm bar mapsensor.</TD></TR></TABLE>
A missing link blocks boost from the MAP Sensor so if you are using a stock ecu with an AFC or another fuel controller. You will get a check engine light if your stock ecu sees positive manifold pressure (aka boost) You cannot run a GM 3 bar map sensor unless you have some sort of ECU like a Hondata, Uberdata, AEM EMS, Crome etc etc which can rescale for the GM 3 bar map sensor. Hope this helps
Old Jun 24, 2007 | 11:30 AM
nihad's Avatar
Default Re: ? mapsensor (Boostfed.com)
well i just want to get my d16a6vtec running and i dont have any chipped ecu or standalone systems i have a p28 p30 ecu that is chippped but i am obd0 on my hatch and that ecu came with my 93dx b16a later i might switch to obd1.
baybee_boy
Jul 27, 2005 11:32 AM
teggreen4
May 22, 2005 11:55 AM
redlseg
May 11, 2005 06:48 AM
gsrt2c
Jun 8, 2003 05:35 AM
dc r-spec
Jun 4, 2002 11:36 PM
