Will stock b18b cams make power to 8k?
Old 06-25-2007, 12:44 PM
Rooftop voter's Avatar
Default Will stock b18b cams make power to 8k?
I'm about to buy a built up b18b and I know I will be able to rev it higher, but will the cams still make power to 8K which is where I want to take it?
Old 06-25-2007, 12:52 PM
DaveF's Avatar
Default Re: Will stock b18b cams make power to 8k? (Rooftop voter)
no they fall flat off around 5k. LS SUCKS
Old 06-25-2007, 01:12 PM
Default Re: Will stock b18b cams make power to 8k? (dturbocivic)
I have a dyno of my stock LST making power to 7k, although the torque starts falling off around 6.5 K.
Old 06-25-2007, 02:30 PM
Bump
Old 06-25-2007, 02:48 PM
non-VTEC's Avatar
you wont make much more power over 7300-7500rpm.
the torque will drop off pretty fast after 7k anyway.........
Old 06-25-2007, 02:52 PM
Default Re: Will stock b18b cams make power to 8k? (non-VTEC)
Even with upgraded valve train and a PnP? I'm gonna switch it out anyway with the a b16 head I got anyway, I just wanted to know.
Old 06-25-2007, 03:39 PM
non-VTEC's Avatar
if you ported the LS head and got a good flowing intake manifold (skunk2, blox, victorX) then you might make some decent power a little over 7k.
maybe even some adjustable cam gears to tune/shift the power band higher but you will sacrifice low end/spool time.
but honestly why bother?...you just said you will put a vtec head on in the future so just save your money for that setup instead.
Old 06-25-2007, 03:59 PM
Yeah, thats what I'm gonna do, but I'm putting a b18b block with a ported and polished head into the car now, and I wanted to know were this one was going to make power to so I know where to set the redline at. It's built so I figure i'd run 15 psi and rev it out to 8k, and swap the head later.
Old 06-25-2007, 04:34 PM
Unceasing Measure
Archidictus's Avatar
The cams won't make power over about 7400rpm regardless of the work done to the head. There's only so much lift and duration in the lobes, and that's the rough maximum. If you're using a B16 head in your build it doesn't matter anyway because you won't be using non-VTEC cams.
PS - it's not necessary to run super high rpm when boosting.
been there done that
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rooftop voter &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, thats what I'm gonna do, but I'm putting a b18b block with a ported and polished head into the car now, and I wanted to know were this one was going to make power to so I know where to set the redline at. It's built so I figure i'd run 15 psi and rev it out to 8k, and swap the head later.</TD></TR></TABLE>
that's why you retune with the new head
Old 06-25-2007, 05:52 PM
HiProfile's Avatar
The tune from a non-vtec head will be nothing like the tune needed for the vtec head - not one bit. You've also never run a boosted motor, at least not a streetable one. I hit redline the other day, only because the clutch started slipping. Other than that, its been a few months, and its WAY faster than any other motor I've driven that had to be taken to redline.
Old 06-26-2007, 05:17 AM
Default Re: Will stock b18b cams make power to 8k? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
The tune from a non-vtec head will be nothing like the tune needed for the vtec head - not one bit. You've also never run a boosted motor, at least not a streetable one. I hit redline the other day, only because the clutch started slipping. Other than that, its been a few months, and its WAY faster than any other motor I've driven that had to be taken to redline.</TD></TR></TABLE>
I'm running a boosted motor right now?
Greenery18
15
02-21-2007 07:11 PM
bOOsTiNSoHcVtEc
06-29-2005 05:23 PM
DragSource
10-03-2004 10:48 AM
DIRep972
05-05-2002 09:04 PM
b18bvudoo
01-17-2002 01:39 AM
Quick Reply: Will stock b18b cams make power to 8k?
