stock block question
Old Jun 20, 2007 | 07:15 PM
integraRS-T's Avatar
Default stock block question
i got a 94 rs b18b1 164k dosent burn oil and runs pretty damn strong ,i was wonderin how much boost i could run on it without shoting a rod through the block and what kind of whp and tq can i get safely[stats say 8psi safe on stock engine]but what about the mileage i do have exedy stage 1,mls head gasket,arp head studs,that should hold a litlle bit of bost right?
Old Jun 20, 2007 | 07:27 PM
doood's Avatar
been there done that
Default Re: stock block question (rsracer)
do compression and leakdown tests. if those come out good, boost away. you can make 200whp and blow it. or you can make 300whp and be safe. it's all in the components used and the quality of the tune.
Old Jun 20, 2007 | 07:36 PM
Default Re: stock block question (doood)
what numbers WOULD i liaek to see on a compresion test and what about the leack down just want some heads up before i go to the mechanic unles i can do those tests my self if someone would help me ill be thankful
Old Jun 20, 2007 | 07:47 PM
doood's Avatar
http://www.c-speedracing.com/h...n.php
http://www.c-speedracing.com/h...t.php
blacc_ej1
May 10, 2011 03:17 AM
jrod95cpe
Feb 1, 2009 11:15 AM
integra6650
May 9, 2004 06:18 PM
quik sol
Mar 7, 2004 12:19 AM
