Borg t04B Turbo In B16a
Re: Borg t04B Turbo In B16a (b16a4)
i just sold my borg to4b to someone that has a v8 because i was told the exhaust housing is to big for a 4 banger.what are the spec's on the turbo?
Re: Borg t04B Turbo In B16a (HondaCivicSiR1)
thanks for the reply
this is the turbo im talking about
https://honda-tech.com/zerothread?id=2019520
yes that would be ok here is what i had
https://honda-tech.com/zerothread?id=1989695
ok so i had a Borg Warner to4b it has a 1.10 A/R T4 is it a twin scroll.The compressor wheel measures 54mm or 2.115 inches for the Inducer and 2.675 inches for the Exducer.
In this case, its not the compressor that you should be worried about. A 1.10 T04 turbine/housing, even if its divided, will take forever to spool on a 1.6L. The one in that thread I'm not sure about, it seems like its a t4-spec housing/turbine with a t3 flange.
Re: Borg t04B Turbo In B16a (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">In this case, its not the compressor that you should be worried about. A 1.10 T04 turbine/housing, even if its divided, will take forever to spool on a 1.6L. The one in that thread I'm not sure about, it seems like its a t4-spec housing/turbine with a t3 flange.</TD></TR></TABLE>are you talking about the thread b16a4 posted or the one i posted?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 »</TD></TR><TR><TD CLASS="quote">HondaCivicSiR1, hey man, what turbo are you going for? i might as well just get me a garrett</TD></TR></TABLE>i just got a garrett t3/t4 with a stage 5 wheel 70 a/r intake and 80 exhaust.should be great on my jdm gsr motor in my ef hatch.
