not making full boost..
Old Jun 21, 2007 | 12:54 PM
blinger's Avatar
Default not making full boost..
Car was running good making 10psi but now its only boosting til 5psi .. Pretty sure there are no leaks.. I've checked over the couplers they all seem good .. The only thing i've done under the hood is I took the air filter off the turbo until I get a new one.. (thing was crazy dirty, looked like it wouldnt get air at all).. I put a screen on until I can get another cone for it
Old Jun 21, 2007 | 12:56 PM
SovXietday's Avatar
Default Re: not making full boost.. (blinger)
Check for exhaust leaks.
Old Jun 21, 2007 | 01:20 PM
A.E Motoring's Avatar
Default Re: not making full boost.. (SovXietday)
exhaust wouldnt have anything to do with it, has to be a coupler, u can run open down pipe and still boost. might be a tear in there somewhere
Old Jun 22, 2007 | 07:58 PM
sohc-8's Avatar
i think what he meant by exhaust leak is a exhaust leak pre-turbo
Old Jun 22, 2007 | 08:43 PM
Dmc1's Avatar
Default Re: not making full boost.. (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">exhaust wouldnt have anything to do with it, has to be a coupler, u can run open down pipe and still boost. might be a tear in there somewhere</TD></TR></TABLE> It would if the leak was in the manifold. BUt I'm with you it's probably a coupler or a vac line.
Old Jun 23, 2007 | 05:28 AM
Harassing Herbs's Avatar
Default Re: not making full boost.. (Dmc1)
check your manifold. i have found numerous leaks from hoses being cracked/blown off/just not tight
Mr_Bojangles
Feb 11, 2005 02:08 PM
95excoupe
Aug 24, 2004 04:23 PM
Diego Boost
Feb 1, 2003 11:12 AM
01ITR#700
Sep 5, 2002 12:27 PM
vtecsiqt
Feb 27, 2002 07:32 PM
