To vent or not to vent my hood.
I'm thinking of altering my CRX hood with some type of vent to get rid of the heat soak in my engine bay. On a summer day my water temps rise to over 210 degrees leaving me to turn on the heat full blast to bring things down. I've tried just about everything to cool things down with little success. So far I've wired the fan to run constant, bought a Fluidyne rad/slim fan, installed a Jackson racing 180 degree thermostat , did the washer trick to raise the hood up and tried water wetter. Has anyone modified their hood with a vent or scoop? If so post up your pics to give me some ideas.
Thanks
Thanks
In theory, a vent should work pretty good. will give the radiator some more airflow over it with the air having a place to escape, and with the (hopefully) suction effect the vent creates.
raising the hood up isn't going to work very well. the area right by the windshield is a high pressure zone because the air stagnates there. air inside the engine would not want to exit there.
a scoop might help... but my first choice would be a vent, ala invader style hoods.
Re: To vent or not to vent my hood. (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Oups missed the hood shimmed. Post a pic of the front of ur car. Possibly some rad shrouds to grab more air</TD></TR></TABLE>
Re: To vent or not to vent my hood. (Mr.Death)
One thing. Get rid of that fan and get a FAL on there i went from a 10" to the FAL and noticed a big difference. Do not have the fan running 247 not good . Sucks up power in the alternator and never alows the engine to warm properly.
I would first try draining the system. Distilled water and water wetter. Bleed the system. Fal fan on the stock Thermo switch.
On the right side of the rad if you are standing in front of the car built a striaght piece of alum to go to the front of the bumper as much as it can as to create a pressure zone in front of the rad. Cause most of the air will turbulance in the front and will find the easyiest path which is the drivers side with no rad.
I dunno if this makes sence??
I just was on the Fal site and their fan flows 1250 cfm while the infinate auto fan flows something like 1550 cfm. Still a good idea to change fans??? I guess the shroud draws more air out than the unshrouded infinate slim fan.
http://www.flex-a-lite.com/aut....html
TECH SPECS
# 125 (BLACK)
# 125R (RED SHROUD)
# 125B (BLUE SHROUD)
AIR FLOW (C.F.M.)
1250
BLADE DIAMETER
12"
FAN DIMENSIONS
15" X 13 1/2" X 2 3/4" THICK
AMP DRAW
10
FAN R.P.M.@13.5VDC
2000
NUMBER OF BLADES
10
FAN BLADE ANGLE
160
So its 2.75" thick
TECH SPECS
# 125 (BLACK)
# 125R (RED SHROUD)
AIR FLOW (C.F.M.)
1250
BLADE DIAMETER
12"
FAN DIMENSIONS
AMP DRAW
10
FAN R.P.M.@13.5VDC
2000
NUMBER OF BLADES
10
FAN BLADE ANGLE
160
So its 2.75" thick
See here is the thing im tring to think of the post on another car forum. They were testingout all the fans. Sure they flow lots on a bench with there own shrouds.
The 10" fan will only flow 1550 cfm in the 10" so say like 4-6 tubs are not getting any cerculation. the fal will pull air across the whole rad. If the fan u had now was shrouded then yes it would cool better. Its like the V8 guys slapping a 12" fan on there stangs and complaining about heat soak issues. then going back to a mechaincal fan or a nice shrouded one.
I would personaly go to a Fal fan due to ur room and make one plate to draw air to the rad. like in the pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Another option JDM front end has alot more openings </TD></TR></TABLE>
Yeah if I had the cash....til then I will experiment on a spare hood with some vents and see if my temps come down a bit. So no ones venting their hood in the FI world?? Post em up!!!!!!!!!!!!!!!
