What next?! Turbo b18a
Well im going to be spending more on my turbo build, what do you guys think I should work on next? Should I should work on my fuel? Or start going in the motor, head work, lower end?? I just want more power and more boost currently street tuned at 7psi, here is whats done w/ the motor already
b18a1 133k Just compression tested at 175 across the board
precision sc6031e turbo
rev log-style manifold
Tial 38mm wastegate
dsm 450cc injectors
supertech valves
arp head studs
3" downpipe
vibrant flat black muffler
new timing belt
new timing belt tensioner
new water pump
hondata s300
p28 ecu
cometic headgasket
odb0 to odb1 conversion
odb1 distributor
rev manifold
ebay bov
ebay fmic
iridium spark plugs
Tial 38mm wastegate
dsm 450cc injectors
supertech valves
arp head studs
3" downpipe
new timing belt
new water pump
hondata s300
p28 ecu
cometic headgasket
odb1 distributor
rev manifold
ebay bov
ebay fmic
iridium spark plugs
I can't beleive no one has mentioned tuning.
I say upgrade the injectors, get a walbro 255HP, and take the car to someone who is reputable in tuning hondata.
It was street tuned when everything was put on. Im going to have dave at whip factory dyno tune it at 10psi in a few weeks.
Question : Will the dsm injectors be good with the walbro fuel pump? Or should I upgrade anyways. If so what size?
thx for everyones help so far btw
official honda whore
Re: (TsujenDB1)
get the 255 pump and get bigger injectors, if you think you will have a built block in the future i would get 880's or 1,000's if you wanna go all out and not have to worry about them again
then easy ways to make power are crower 403's with valvetrain, get a 3 bar map sensor so you can turn up the boost, stock block you should be abe to put down 300whp pretty easily
Re: (coptzer)
Get the kit 'complete' first:
dsm 450's
ebay bov
iridium spark plugs
Get any other injector, a name-brand bov, and normal NGK spark plugs. Reliability is the main factor for that.
Next slap in some forged rods & pistons, maybe a valve job, refresh the seals in the head, and it should be good for 50k more HARD miles.
dsm 450's
ebay bov
iridium spark plugs
Re: (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost »</TD></TR><TR><TD CLASS="quote"> What made you want to paint the valvecover?</TD></TR></TABLE>
Shrek?
Shrek?
Re: (chris_tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris_tune »</TD></TR><TR><TD CLASS="quote">Shrek?</TD></TR></TABLE>
