help with plug selection bkr7e-11 ?
Old Jun 20, 2007 | 03:41 PM
SwappedTURBOegg's Avatar
Default help with plug selection bkr7e-11 ?
ok guys doing some tuning here on my GSR manley rods ross racing pistons crower allmotor cams,Holset H1E, its been going pretty well.
Yesterday i was trying to get the 1000s right and ended up fowling out a set of r5671a-8's.
im starting to think they were too cold in the first place. i picked up a set of bkr7e-11 today and got some real tuning done. its in the mid 10s WOT around 20 PSI 8.2 compression GSR stock sleev 81.5
the goal of this build is 500 on 93 octane hints the super low compression. IS it safe with this setup im running now? it pulls HARD with no det sounds or hiccups. timing is in the 14* mark in higher boost regions. trying to be safe here. on the right track?
if anyone would like to take a look at my crome bin file i would be extremely gradafide [is that even a word lol] just shoot me ur email add and ill send it along
Old Jun 20, 2007 | 08:05 PM
Default Re: help with plug selection bkr7e-11 ? (SwappedTURBOegg)
cool noone knows
getting some 8s tomorrow to be safe
turbo hondas are fast i love mine but im always afeade its guna break lol
Old Jun 20, 2007 | 08:11 PM
Turbo-charged's Avatar
you should have no problem idling 1000's on some 8's. good luck
what turbo are you using
Old Jun 20, 2007 | 10:30 PM
SOHC_MShue's Avatar
yea i wouldn't run any less than 8's for that kind of power. If they are fouling so quick then you are too rich at idle. Maybe try tuning idle with some hotter plugs if you are having trouble with it.
Old Jun 20, 2007 | 10:58 PM
Default Re: help with plug selection bkr7e-11 ? (SOHC_MShue)
I have it idling MUCH better now its alil lean 16s but i can deal with it.
ordered some 8s at my local murrys tossing them in tomorrow and hitting track friday and dyno saturday if it stays together lol. the turbo is holset H1E its bigger than the HX35 and abit smaller than the HX40,actually predasesor of the HX40 flows aorund 60lb min maybe more. not much info on thees guys. im going to boost as much as my wastegate lets me. HKS 50mm dont know what spring is in it but i hit boost cut at at 17 psi so its either 18 or 22 [largest hks makes] running on pump gas. well see what happens.
Old Jun 21, 2007 | 05:24 AM
alpha's Avatar
What's your timing at idle? What exhaust manifold and cam setup do you have? Curious as you said you're going for 500whp on pump gas (93 I assume). I would buy two sets of 8's. One so you can get a fresh read on the plugs. And keep a set of 9's so you dont kick yourself on the dyno
Old Jun 21, 2007 | 08:02 AM
Default Re: help with plug selection bkr7e-11 ? (alpha)
cams are crower CTR+ manifold is fullrace top mount timing is 14 at idle [extra safety] 4" downpipe\dump mid car. 93 octane
Old Jun 21, 2007 | 08:18 AM
alpha's Avatar
Stock bore? What's you using to tune with? Advance the timing to 16* at the idle load/break points and try using another rpm break point with the ignition advanced a more. It's not going to hurt anything. They like what they like. 4G63's I have to advance the idle quite a bit when/if it drops using an idle ignition offset table.
Old Jun 21, 2007 | 08:31 AM
its a 81.5mm using crome i have the maps set at 16, also have have base at 16 but planned on setting it at 14.
GsrRussell
Jul 27, 2008 08:13 PM
wfocrx
Oct 8, 2006 06:14 AM
usafa2010
Jul 12, 2005 07:18 PM
crxY-49
May 3, 2004 10:05 AM
wrXtian
Oct 17, 2002 10:16 AM
