dyno chart.......is it good....help.
Old Jun 26, 2007 | 12:44 AM
dc2greddy's Avatar
Default dyno chart.......is it good....help.
i just dyno my turbo teg and its kinda of low for a turbo.........
Old Jun 26, 2007 | 12:45 AM
dc2greddy's Avatar
Default Re: dyno chart.......is it good....help. (dc2greddy)
this was at 7psi......
Old Jun 26, 2007 | 12:54 AM
KeyserSoze's Avatar
Your gonna need to give a little bit more info than just that. If its a ls @ 7psi on a straight t3 I would say its not bad. A gsr @ 7 psi on a 35r better be quite different.......get my drift??
What motor, what turbo, what manifold, what exhaust, compression ratio.....etc.
Just from a quick look I'd say your runnin a bit lean. Would b a good idea to richen it up ~.5 pt or so. I'd also guess its a vtec engine with crossover set to ~5300rpm....needs a bit of fuel there as well. I'm no pro tuner, this is just what I see at first glance. Give us more info.........
Old Jun 26, 2007 | 02:19 AM
dc2greddy's Avatar
Default Re: dyno chart.......is it good....help. (KeyserSoze)
sorry its a gsr with a greddy kit......set to 7psi..........and i have the 2inc downpipe greddy give me...with a 3inc exhaust tune on crome...so iam running lean.......need a adjustable fuel pressure right give it how much psi.....what is stock to.......stock psi for the fuel pressure.......
Old Jun 26, 2007 | 03:03 AM
importdude2000's Avatar
here is my ls at 8psi
109F at ctr room
stock ls
t3/t4 54 trim
i say thats not bad for a greddy kit with 7psi
Old Jun 26, 2007 | 05:12 AM
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2greddy &raquo;</TD></TR><TR><TD CLASS="quote">sorry its a gsr with a greddy kit......set to 7psi..........and i have the 2inc downpipe greddy give me...with a 3inc exhaust tune on crome...so iam running lean.......need a adjustable fuel pressure right give it how much psi.....what is stock to.......stock psi for the fuel pressure.......</TD></TR></TABLE>
that really isn't bad for that kit
Old Jun 26, 2007 | 06:53 AM
ndogg's Avatar
you don't need an adjustable fpr unless your injectors are aready maxed out. just add more fuel using crome.
Old Jun 26, 2007 | 06:54 AM
PrecisionH23a's Avatar
You don't need any type of FPR. Your a/f's look about .4-.6 leaner than what I typically shoot for. Changing your base fuel pressure will off course throw off your entire tune... so add about 4%-6% fuel under load opposed to dicking with playing with a FPR. Going richer will also kill a little power... but it will keep your engine safer.
Old Jun 26, 2007 | 09:24 AM
patrick4588's Avatar
how come his torque curve falls off so bad?
Old Jun 26, 2007 | 09:53 AM
SovXietday's Avatar
Default Re: (patrick4588)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">how come his torque curve falls off so bad?</TD></TR></TABLE>
Small turbo getting choked at high Rs.
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2greddy &raquo;</TD></TR><TR><TD CLASS="quote">sorry its a gsr with a greddy kit......set to 7psi..........and i have the 2inc downpipe greddy give me..........</TD></TR></TABLE>
Old Jun 26, 2007 | 10:14 AM
dc2greddy's Avatar
Default Re: (FUCATYPR)
what can i do about the getting choke part. anyone know how much i will be running at 10psi.......
Old Jun 26, 2007 | 10:19 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (dc2greddy)
Get a 3" downpipe and run more boost.
Old Jun 26, 2007 | 10:20 AM
dc2greddy's Avatar
Default Re: (Archidictus)
just the down pipe or the greddy elbow too........
Old Jun 26, 2007 | 10:56 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2greddy &raquo;</TD></TR><TR><TD CLASS="quote">just the down pipe or the greddy elbow too........</TD></TR></TABLE>
or a real turbo kit
Old Jun 26, 2007 | 12:14 PM
Tony the Tiger's Avatar
Upsize everything starting from the turbine outlet (elbow/downpipe, exhaust, muffler, whatever). If you want a nice flat torque curve, best to go with 3" everything.
Old Jun 26, 2007 | 04:42 PM
Cyberdx16's Avatar
Default Re: (Tony the Tiger)
i think tony just said "upsizing from turbo back" should get u into 250whp
Old Jun 26, 2007 | 09:57 PM
numbnuts22715's Avatar
My numbers are in my sig...
boosting 8 spiking to 13... i dunno wtf is up witht he huge spike.
Stock greddy downpipe with a 2.25 inch shity catback.
Soon ima upgrade to 3" exhaust and should be good for close to 300.
edit: also, finding an elbow to fit it is really hard. I dont know of any company that makes them, so it would have to be custom, and it would probably cause oproblems when trying to keep ps and ac... If you get the downpipe and exhaust, you should get close to your goals.
Old Jun 27, 2007 | 10:38 AM
dc2greddy's Avatar
Default Re: (numbnuts22715)
you guys keep on saying downpipe but what about the elbow.......do i change that too........or leave it and just up size my downpipe to 3inch.
Old Jun 27, 2007 | 10:45 AM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2greddy &raquo;</TD></TR><TR><TD CLASS="quote">you guys keep on saying downpipe but what about the elbow.......do i change that too........or leave it and just up size my downpipe to 3inch.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 &raquo;</TD></TR><TR><TD CLASS="quote">i think tony just said "upsizing from turbo back" should get u into 250whp</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Upsize everything starting from the turbine outlet (elbow/downpipe, exhaust, muffler, whatever). If you want a nice flat torque curve, best to go with 3" everything.</TD></TR></TABLE>
Old Jun 27, 2007 | 12:43 PM
Like I said.. nobody makes an elbow for it, so it would have ot be custom.
The elbow wouldnt hurt or help it that much, so just upgrading the downpipe and exhaust would be enough to get you in the 300's or so. If you want much more hp than that, you really need a new turbo.. I'm building my engine and going to upgrade to a gt30.
Old Jun 27, 2007 | 06:15 PM
hb_guy's Avatar
well think about it this way... what kind of power are you making stock at the wheels?? 140-150ish?? 65-75 hp from 7 psi isn't that bad.. get a larger downpipe and you will see another 10-15 whp..
Da1WiTsKiLz
Sep 1, 2015 09:02 AM
TigsteRz
Honda S2000
64
Apr 18, 2013 02:35 PM
Project:PULL
Jan 12, 2007 11:54 AM
DA-nteg
May 29, 2004 01:24 PM
Maxime
Jul 26, 2003 01:42 PM
