Overheating/compression question/problem
Old Jul 14, 2007 | 11:24 AM
juanb's Avatar
Default Overheating/compression question/problem
My car started with overheating problems around 2 months ago. At first i was running a stock radiator and thought that was my problem. I ended up borrowing a fluidyne from a friend and that kind of helped with the overheating, but it would still overheat at times, just randomly.
I ended up buying my own radiator and replaced the thermostat problem continued. So i thought maybe there is something cloging the system (maybe heater core). I looped the heated hoses to bypass the heater core and same problem.
On a cold motor compression quickly rises to 180 all across, on a hot motor compression stuggles, but gets to 180.
My questions, Maybe headgasket? Also is compression on a warm motor SUPPOSED to be higher then a cold motor?
Any help or advise is appreciated.
Old Jul 14, 2007 | 11:47 AM
RTW DC2R's Avatar
if you turn the heat on, does it stop overheating?
Old Jul 14, 2007 | 12:23 PM
Mykizism's Avatar
Default Re: Overheating/compression question/problem (juanb)
compression should be higher on a warm motor then a cold motor. also on the same note, compression should be checked with the motor at operating temp.
Old Jul 14, 2007 | 05:23 PM
juanb's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">if you turn the heat on, does it stop overheating?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">compression should be higher on a warm motor then a cold motor. also on the same note, compression should be checked with the motor at operating temp.
compression was checked at operating temp.
Old Jul 15, 2007 | 03:53 PM
juanb's Avatar
no ideas?
Old Jul 16, 2007 | 08:45 AM
batboyvaj's Avatar
Default Re: (juanb)
you have to increase the airflow to your rad. or your fan is on backwards
sirguy01
Jul 6, 2006 09:03 PM
92TypeR
57
Jan 20, 2006 09:40 AM
prelude994e
Nov 2, 2004 07:42 PM
sjracer
Jan 21, 2003 03:28 AM
