Misfire in Boost
Old Jul 10, 2007 | 01:16 PM
LST2's Avatar
Default Misfire in Boost (solved)
I have recently started having misfire issues. It only happens when I get on it and is usually over 5k rpm and boost about 1bar. I just changed my spark plugs (I use the vpower 8step gapped to about .26). It is a pretty constant high speed stutter and won't build boost past 1bar. Here is my basic setup:
T3/T67
MSD blaster coil, dizzy cap and plug wires (1 yr old)
RC750cc
Crome Tuned
I need to check the datalog on the AFRs but they were running about 11.8 in high boost before I ran into the misfire problems. From reading my gauge it may be due to being to rich now even though I did not change my tune. I am going to check later and stay on it to see if the AFRs dip too low, maybe I need to lean it out for some reason.
Any other ideas?
__________________________________________________ _______________
Update
I ended up solving my problem last night. I first did a pull and the datalog showed 11.8 all the way across, so it was not the fuel. Then I started noticing that it started happening around the VTEC engagement point. I went under the hood and checked the connections to the solenoid and there must have been a short somewhere because I had no misfires after that.
Regarding the gap, max boost for me is about 26psi (500+wph with meth/water injection) so I am not sure if I could run a gap as low as .20.
Modified by LST2 at 6:10 AM 7/11/2007
Old Jul 10, 2007 | 03:07 PM
tepid1's Avatar
Default Re: Misfire in Boost (LST2)
I just had the same problem.... trashed my motor too.
It was because I built a custom wire harness and the dizzy was getting interferance some how.
Good luck.
Old Jul 10, 2007 | 03:09 PM
SovXietday's Avatar
Are you sure that dist isn't dying?
Old Jul 10, 2007 | 04:43 PM
sc4dr's Avatar
Default Re: Misfire in Boost (SovXietday)
Does the distributor have red dust in it?
Old Jul 10, 2007 | 04:49 PM
speedlabx2005's Avatar
Default Re: Misfire in Boost (sc4dr)
i had same issue as you i gapped the plugs to .021 and it went away. i didn't think it would work but to my surprise runs great now. if u think its your dist. just get a lifetime warranty igniter from autozone or the whole distributer lifetime warranty its worth it.
Old Jul 10, 2007 | 06:15 PM
TurboLSVtecTeg's Avatar
Default Re: Misfire in Boost (speedlabx2005)
Try a smaller gap on the plugs. Even with the MSD coils(any besides something like the HVC II coil). You will need to run a smaller gap then a .26. Take it down too .20-.22 and go from there. Ive had to gap cars as low as .16. This has been on lower boost(less than 20 psi).
umair
Oct 17, 2011 08:48 AM
torr
Aug 29, 2004 01:06 PM
shermanyang
Aug 6, 2004 10:28 AM
shermanyang
Aug 5, 2004 09:00 PM
b_ron007
May 19, 2004 06:29 AM
