oil restrictor?
Old Jul 12, 2007 | 12:13 PM
blackmugensivic's Avatar
Default oil restrictor?
I've heard that on a honda when you turbo it that it is wise to put some kind of oil resrictor in the oil feed line to reduce the pressure, because the engine oil pressure is to high and will blow the seals in the turbo. I don't know its just something i heard and wanted a second opinion on
Old Jul 12, 2007 | 12:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: oil restrictor? (blackmugensivic)
this is what i have been told,
-3 fine without
-4 needs a restrictor
in my exp, my old to4b never leaked w/o a restrictor and -3 line.
my t3t67ho did with -3 line, but i have been told lotsa people have had leakage issues with that turbo.
Old Jul 12, 2007 | 01:22 PM
1992Si's Avatar
This how we did a restrictor on a buddy's car. We install a shut off valve that is about 1/3 open then install a gauge after it . We can adjust the pressure until it's below 40psi at full throttle.
After your happy remove the **** so no one will screw with it.
Old Jul 12, 2007 | 11:20 PM
quicksilver1689's Avatar
i ♥ snails
damn thats a neat idea you got there
Old Oct 29, 2007 | 06:17 AM
B18badboy's Avatar
Default Re: (quicksilver1689)
If that's a 1/4" copper oil feed then it's bound to leak in the future. Rigid connections + compression fittings + vibration = mass oil leaks.... trust me i've been down that path a few times until I upgraded to ss braided throughout
duf2570
Oct 13, 2012 03:14 PM
x92preludesix
Mar 21, 2007 12:35 PM
screen_name
Apr 23, 2005 07:22 AM
wade
Oct 10, 2004 07:38 PM
GruvyTune
Feb 5, 2002 03:27 PM
