my future setup
Old Jul 8, 2007 | 07:56 PM
b18_crx's Avatar
Default my future setup
im planning on building something similar to what my friend built in his civic. i just started ordering parts and im already upto $2500 dollars. i havent ordered the turbo or the oil/water lines and im thinking the turbo might be overkill for the motor. if you have any input please let me know.
here is his setup
block: golden eagle sleeved JDM B16A (81.5mm bore)
block will be step decked,o-ringed,line bored,bored & honed.
JE 9.0:1 pistons
EAGLE h-beam rods
ARP rod bolt's
ARP head stud's
OEM bearings
head:
2000 civic si head
hot tanked,ported-polished,decked and will have a 3 angle valve job.
Ferrea valve springs & retainers
Ferrea racing valves 1.mm oversize
stock 2000 type r camshafts
Edelbrock victor x intake manifold
Hondata intake manifold gasket
Cometic head gasket
AEM cam gears
stock type r throttle body (bored out to a 64mm)
OEM usdm type r red valve cover
of course new oem belts and gaskets
drivetrain
usdm integra type r LSD transmssion
Competition stage 4 clutch kit
Gator stage 3 racing axles
turbo:
Inline pro ss t4 exhaust manifold
Garrett gt35r (ball bearing) turbo (s-housing)
82mm,56 trim,0.70 a/r oil & water cooled
Fast-Turbo stainless braided turbo oil line kit & water lines for turbo
tial 44mm wastegate (red)
custom aluminum 2.5" intercooler piping all the way around
precision large front mount intercooler
custom 3" ss downpipe
greddy type-s blow off valve
fuel:
rc 750cc saturated injectors
walboro 255lph fuel pump
aem fuel rail
engine managment/electronics :
GM 3 bar map sensor
MSD digital 6 plus ignition control box
MSD distributor cap
crane cams fire-ball ignition coil
aem wideband ,uego controller
greddy profec type s electronic boost controller
OEM honda NGK (blue) spark plug wires
im not a newb by any means just wanting others feedback
Old Jul 8, 2007 | 08:06 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
get bigger injectors!! and that tranny has some short short gearing for turbo
and if 2500 is all you've spend, you've got a LONG way to go
and i wouldn't get the msd ****... if your gonna get aftermarket ignition go with the good ****!
Old Jul 8, 2007 | 08:11 PM
iBrandon's Avatar
Default Re: (tannerLSt)
M & W ignition!
Old Jul 8, 2007 | 08:14 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
yes, get M&W ignition, i can't remember what coil was best to use with it, think it was crane
you ballin' now Jose ?
Old Jul 8, 2007 | 08:24 PM
b18_crx's Avatar
nope ill pm u
Old Jul 8, 2007 | 08:26 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
if your buying springs and retainers why not get better cams? if it were me i would get oem axles with a lifetime warranty. from the size of your injectors im guessing your shooting for around 400hp?
Old Jul 8, 2007 | 08:34 PM
nihad's Avatar
what wrong with short gear ratios. Its better than long gear.
Old Jul 8, 2007 | 08:39 PM
jdm_dc_fan's Avatar
theirs a debate that short gears on a high hp car will have traction problems, but i think any high horse power FWD will have traction problems period.
Old Jul 8, 2007 | 09:11 PM
slodel's Avatar
Default Re: (jdm_dc_fan)
oem headgasket
Old Jul 9, 2007 | 03:14 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan &raquo;</TD></TR><TR><TD CLASS="quote">theirs a debate that short gears on a high hp car will have traction problems, but i think any high horse power FWD will have traction problems period.</TD></TR></TABLE>
too short of gearing is not always good.... anything that will help traction is good
Old Jul 9, 2007 | 04:39 AM
SPOOLINmatt's Avatar
i havnt had a problem with MSD in 5 years or maybe 6 years.
Old Jul 9, 2007 | 05:44 AM
red_crx's Avatar
Default Re: (slodel)
looks good so far.........If I were you I would probably get bigger injectors
Old Jul 9, 2007 | 06:09 AM
Doostur's Avatar
I had same problem with injectors... got the 750s with the same turbo. Need to pick up some 1000s now.
Old Jul 9, 2007 | 06:30 AM
morgan@synapse motorsport's Avatar
a few things i noticed....
i would suggest oem head gasket
stock axles
unless you are shooting for more than 500whp i would use a gt30r
if you are shooting for 400-500whp 880cc injectors, anything more than that 1000cc injectors
500 or less get the competition stage5 clutch, more than 500 get a twin disk
what engine management do you plan on running?
what are your power goals, further suggestions could be made
Old Jul 9, 2007 | 11:08 AM
TheShodan's Avatar
Moderator
Ah, the final voice of reasonable thought on such a subject.
illassek9
Sep 12, 2011 11:58 AM
illassek9
Aug 24, 2011 07:00 AM
hondaclassifieds
Mar 5, 2009 12:53 PM
official_del-sol
Sep 3, 2008 04:07 PM
official_del-sol
Jul 7, 2008 04:08 PM
