BOV Tial vac problems
Old Jul 8, 2007 | 08:31 AM
Jupe's Avatar
Default BOV Vaccum Problem
On my 06 SI, I have a Tial BOV and I connected the vac line to the Intake manifold. Just like Greddy said to do. When I did that the BOV is slightly open @ idle. When I step on the gas it closes, but when the RPMS come back to idle the car struggles to stay started by pulsing between 400rpm to 800rpm. I disconnected the vac that goes to the fire wall and I lost my brakes in the drive way. The break pedal went stiff. Before I lost the breaks it worked but I still had a small compressor surge and then the BOV worked. What would cause that problem?(a leak maybe??) I tried reseting the ECU and nothing the same thing happened when I reconnected the vac line to the fire wall.
I am wondering if anyone knows anything that I can do to fix this???? Thank you
Jupe
Modified by Jupe at 9:45 AM 7/8/2007
Modified by Jupe at 2:14 PM 7/8/2007
Old Jul 8, 2007 | 01:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: BOV Vaccum Problem (Jupe)
being open at idle is normal.
you can go to tialsport.com and look at their tech page to see what spring that valve takes according to engine vacuum produced. BUT if you go too tight, it wont open.
http://www.tialmedia.com/docum...p.pdf
Old Jul 8, 2007 | 01:32 PM
Jupe's Avatar
Default Re: BOV Vaccum Problem (boostedcivicsir)
the default psi is 11. It opens just fine and sounds great, but when the it goes back to idle it pulse and almost dies. It did die twice on me, once while I came to a stop and once in the garage. I have a slight compressor surge still at the begining of the pressure release. I have the vac line on the manifold. So I am using the right one. I don't know why it is giving me such problems????
Jupe
Old Jul 8, 2007 | 02:42 PM
Mr. Badwrench
unless you run a bigger spring, at which you will run into a little surge. call tial and talk to them, they were very helpful.
and vacuum is measured in mm/in of hg not pressure.
Builda'Teg_92
May 14, 2013 11:48 AM
Jupe
Honda Civic (2006 - 2015)
Jul 9, 2007 05:04 PM
eg:R
Jan 31, 2007 01:27 PM
eg:R
Sep 17, 2006 06:47 PM
Aeka GSR
Jun 11, 2002 07:34 PM
