Still have a problem w/BOV
Old Jul 11, 2007 | 07:34 PM
Jupe's Avatar
Default Still have a problem w/BOV
This is what the mechanic said about the Tial 50mm BOV-
The BOV was hooked up. The open line in the top would be used on a recirculated valve, because you run a MAF system with no option to recirc, you cannot install a vacuum line or you begin having problems with the BOV because air is entering the system unmetered. The spring is 9psi, enough to hold the valve closed under boost without a vacuum line from the pressure side of the turbo. We add this line with a one way check valve when boost and spring pressure are close. Thank you
Jupe
Old Jul 11, 2007 | 10:53 PM
dpetro1's Avatar
Default Re: Still have a problem w/BOV (Jupe)
WHAT??? that doesnt make any sense. what kind of car are you driving. hondas run MAP so you dont have to worry about that recirc crap. what problem are you having with the bov? without a vac line hooked up it wont blow off. please clarify what you are talking about!
Old Jul 12, 2007 | 07:25 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jupe &raquo;</TD></TR><TR><TD CLASS="quote">This is what the mechanic said about the Tial 50mm BOV-
Jupe</TD></TR></TABLE>
new mechanic needed STAT
Old Jul 12, 2007 | 07:35 AM
twkdCD595's Avatar
Default Re: Still have a problem w/BOV (TiAL)
his previous posts he says he has an 06 si, and that his boost/ vac gauge reads no vac. and boost is all wrong, blah blah blah. basically he says his mechanic screwed him over or something. dude is all over the place with his post, hard to make sense of all of it.
so how do you pick the proper spring for the tial bov (based on their chart) without accurately or not knowing at all what vac. your engine is pulling?
I dont understand most of his post, what was the question in all that... and what was the part about the MAF?
can we get a translator in here please.
Old Jul 12, 2007 | 08:45 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Still have a problem w/BOV (twkdCD595)
we just did a greddy kit on an o6 si, it is not recirculated. put the vac line on and let it eat. and YES IT MAY STAY OPEN IDLING. if thats the case put a stiffer spring in it.
Old Jul 12, 2007 | 09:26 AM
2.020VT's Avatar
Default Re: Still have a problem w/BOV (boostedcivicsir)
Were can you get stiffer BOV springs?
Old Jul 12, 2007 | 09:45 AM
twkdCD595's Avatar
Default Re: Still have a problem w/BOV (2.020VT)
from the manufacturer or any dealer I would asume.
Old Jul 12, 2007 | 10:05 AM
Topdawgg's Avatar
maybe your mechanic thought he was working on a new eclipse................
inform him that you drive a honda, and then go find a new "mechanic"
Old Jul 12, 2007 | 10:06 AM
Mr. Badwrench
got mine from importparts.com
any tial dealer should be able to get them.
Old Jul 13, 2007 | 08:34 PM
Jupe's Avatar
If I was to get the 12psi spring will it still release pressure @6psi??
mcdonoughEk00
Mar 3, 2014 08:50 AM
1DayIllBFast
Jul 10, 2009 06:22 AM
thid92
Jul 6, 2009 11:21 AM
Dan_Roc
Feb 6, 2007 12:55 PM
RACEPAK
Apr 3, 2006 02:39 PM
