Trying to Find Internally Oiled Turbo? VETS HELP PLEASE..
Thank you for your time....
basically I want to find a turbo that doesnt need a oil line or cooling[coolant] lines. It has a self contained oil system.... does this exist? I have looked and looked...
YES... the turbo gets exhaust gases and gets HOT HOT! but I do NOT want to use my engine oil for my turbo...or cooling lines.... I want a turbo that is a closed system...
is this possible? ANY IDEAS?
thanks....!
thanks....!
Re: Trying to Find Internally Oiled Turbo? VETS HELP PLEASE.. (sharpescalade)
http://www.nasa.gov/
may be able to help with the right funding.
if you're concerned about your oil temps increasing, run a cooler. you don't need a h20 cooled chra, so you can skip the coolant lines. fwiw, the oil passes by quickly in the chra...very little heat transfer occurs from a turbo when it comes to oil.
Re: (quik sol)
Why do u have a problem with using the oil from the engine? Thousands of people run their turbos by using oil from the engine and dont have any problem if thats what your afraid of. What is the main reason u dont want to use the oil from the engine?
Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol »</TD></TR><TR><TD CLASS="quote">ok...why would you need all this for something like a 14b?...</TD></TR></TABLE>
bling factor why else
It's a lot of work, and i think it's pointless for the amount of work you have to do...that's my opinion though.
anyways keep lookin' and you should find one, or do it your self like a post before me said, you need 2 pumps and a reservoir.
Re: (sharpescalade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharpescalade »</TD></TR><TR><TD CLASS="quote">haaa.....
OK... two pumps why? one puller one pusher??
how big of a reservoir do you think a small IHITD05 or 14b....nothing big... and low boost requirements..</TD></TR></TABLE>
push and pull.... you'll also want your turbo to be gravity drained although I seen were it's not but I would think that'll shorten the life of the turbo.
reservoir I say just enough for 1 1/2 quarts.
Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol »</TD></TR><TR><TD CLASS="quote">heres one: http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
Wow thats pretty interesting
i thought garrett developed foil bearings just after WWII to solve the issue of oil and coolant lines, can anyone back me up on this?
you need a turbo with a foil bearing equipped chra
edit: http://en.wikipedia.org/wiki/Foil_bearings
AccordVT
07-30-2008 07:51 PM
riceburnr18
09-29-2007 05:52 PM
