Fuel Sump line question
Old Jul 6, 2007 | 04:28 PM
fmfkid250's Avatar
Default Fuel Sump line question
I Got my sump and my A1000 pump and filters
I have no decided on line
should i go braided stainless? or some sort of hard line
My plan is -10an all the way up and useing the stock feed as the return line
Old Jul 6, 2007 | 05:01 PM
dday00si's Avatar
Default Re: Fuel Sump line question (fmfkid250)
i'm doing the same setup but i'm goin -10 from the sump to the pump and -8 from the filter forward and -6 for the return
i don't think the stock line will be efficient
Old Jul 6, 2007 | 05:17 PM
fmfkid250's Avatar
Default Re: Fuel Sump line question (dday00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dday00si &raquo;</TD></TR><TR><TD CLASS="quote">i'm doing the same setup but i'm goin -10 from the sump to the pump and -8 from the filter forward and -6 for the return
i don't think the stock line will be efficient </TD></TR></TABLE>
I think the Stock feed is slightly smaller then a -6an I really dont see the issue in that
and i am going -10 all the way up
Old Jul 6, 2007 | 05:46 PM
dday00si's Avatar
wouldn't you want to put a line in the tank to return the gas directly to the sump?
Old Jul 6, 2007 | 10:13 PM
ShawnR's Avatar
im useing my stock feed as the return.. some cars like a ek there is no way to connect a steel braided line to it cuase theres no place for a fitting unless u weld one on there. so its easyer to use the stock feed as the return and the stock feed is just abou the same size as -6 u will be fine doing it that way..
Old Jul 7, 2007 | 10:12 AM
fmfkid250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dday00si &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't you want to put a line in the tank to return the gas directly to the sump?
I dont think so it would cause a turbulance in the sump possibly makeing air pockets..
Old Jul 7, 2007 | 02:40 PM
dday00si's Avatar
just my opinion ,but it works
dmotoguy
Mar 2, 2008 10:27 AM
96 GSR-T
Oct 19, 2007 11:28 AM
ShawnR
Apr 13, 2007 03:12 AM
1QwIkEf
Jan 28, 2006 05:05 PM
Blown90hatcH
Mar 3, 2003 09:47 AM
