Fuel Pressure??
Old Jul 13, 2007 | 01:00 PM
jarven093's Avatar
Default Fuel Pressure??
Can anyone tell me what the stock fuel pressure is on a 93 civic ex with a D16Z6 P28 ecu is? And now that i got my self a FPR what is a good pressure for 10 to 15 psi boost?
Old Jul 13, 2007 | 01:12 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fuel Pressure?? (jarven093)
i want to say 35-37 ish?
stock. use it if you want, what FPR is it? b and m command flow? if it is anything that you have to cut the top off of the stocker, sell it. the stock reg is good for more power than you will prob. make at that boost.
Old Jul 13, 2007 | 02:10 PM
jarven093's Avatar
Default Re: Fuel Pressure?? (boostedcivicsir)
this is the FPR i bought its pretty decent i have herd good things from a few ppl.
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jul 13, 2007 | 02:12 PM
agrn93ls's Avatar
specifications i found
vacuum connected 30-38
off vacuum 40-47
Old Jul 13, 2007 | 02:14 PM
jarven093's Avatar
Default Re: Fuel Pressure?? (agrn93ls)
whats that mean vacuum connected 30-38 off vacuum 40-47
Old Jul 13, 2007 | 02:15 PM
agrn93ls's Avatar
you hook a vacuum line to the FPR. with the vacuum line connected its ____ with the vacuum line disconnected its______
Old Jul 13, 2007 | 02:17 PM
jarven093's Avatar
ok i will be haveing the vacc. line connected .... so 35ish should be good? and what was stock fuel pressure anyone know?
Old Jul 13, 2007 | 02:23 PM
agrn93ls's Avatar
the specs i gave you are stock
Old Jul 13, 2007 | 02:24 PM
agrn93ls's Avatar
set it to where when you pull the vacuum line off at idle the pressure goes to about 45. then when you connect it it will go down into the 30's that should be just fine.
on boost. it is more based on what happens while tuning. if you run FMU it dont really matter if your tuning the tuner will set that for ya
Old Jul 13, 2007 | 02:28 PM
jarven093's Avatar
what kinda Fuel press. should i have it at fo 10-15psi boost ...... i have 550cc rc inj. and stock fuel pump ( will that stock pump even keep up with 10-15 psi boost) Thank you guys for helping me figure this out by the way. most ppl on here will jump a man if ya know what im sayin thanks
Old Jul 13, 2007 | 02:32 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven093 &raquo;</TD></TR><TR><TD CLASS="quote">ok i will be haveing the vacc. line connected .... so 35ish should be good? and what was stock fuel pressure anyone know?</TD></TR></TABLE>
ok here is the deal.
line on = no rise in fuel pressure. idle.
line off = atmospheric pressure. wide open throttle fuel pressure. remember there is no manifold vacuum at wide open throttle.
the line off method is for setting what we call base fuel pressure. it is the highest it will be without boost acting on it.
if you are goin turbo on the stock pump, it is a matter of time before it or your engine will expire. replace it with a walbro.
Old Jul 13, 2007 | 02:35 PM
jarven093's Avatar
Ok what if i run the FPR at 45 when vacc. is connected will that be ok also?
Old Jul 13, 2007 | 02:54 PM
agrn93ls's Avatar
pointless.
ARE YOU GETTING TUNED?????
Old Jul 13, 2007 | 03:44 PM
jorge59la's Avatar
you shouldn't be running boost on stock f. pump, period!
Old Jul 13, 2007 | 06:36 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven093 &raquo;</TD></TR><TR><TD CLASS="quote">Ok what if i run the FPR at 45 when vacc. is connected will that be ok also?</TD></TR></TABLE>
no because that will be like 55 off and 70 when boosted.
replace the pump, leave the reg alone. thats what i would do.
32 bucks for a reg and gauge, its your engine. me i wouldnt trust it.
Mr Hammond
Apr 18, 2006 04:08 PM
campbuds
Dec 7, 2004 11:25 AM
wanttorace
Jun 5, 2003 06:28 AM
spankaveli
Apr 8, 2002 05:30 AM
