Question?
Old Jul 10, 2007 | 06:44 AM
jdmb18c1's Avatar
Default Question?
I just had a garret t3/t4 full turbo kit installed on my B16 and I am planing to have a long distance drive from MD to FL its running on 6psi and I never crank the boost any higher but my question is since I have a after market turbo is there a possibillity the turbo will go out. This my first time having a turbo car. Thanks
Old Jul 10, 2007 | 06:46 AM
Schister66's Avatar
Man U FTW
There is always a possibility that something will go wrong. If you keep an eye on it and check your fluids, you should be fine as long as everything was installed correctly. I've put many long drives on my various turbo setups and never had a problem. You should be fine
Jeanious
Oct 11, 2008 05:02 PM
97turboteg
Feb 12, 2006 02:31 PM
channy
May 13, 2005 06:23 PM
