which is best? victor x or skunk2 pro intake manifold?
Old 07-08-2007, 06:14 PM
89hatcher's Avatar
Default which is best? victor x or skunk2 pro intake manifold?
changed my mind about going LS Turbo...now doing LS/vtec turbo...will the skunk2 be efficient enough?
Modified by 89hatcher at 9:44 PM 7/28/2007
Old 07-08-2007, 06:22 PM
Armed Ferret's Avatar
honestly, unless you're going to stay way up in the high revs, the blox oughta do just fine. same as the skunk2, just less expensive.
the edelbrock is fantastic for the higher rev range, but you lose a lot of midrange torque in sacrifice.
all comes down to where you want the powerband.
Old 07-08-2007, 07:46 PM
New User
Boostfed's Avatar
On an LS unless you have some wild cams and rev high RPMs the Skunk2 will be a much better choice for you.
Old 07-08-2007, 09:14 PM
dday00si's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">On an LS unless you have some wild cams and rev high RPMs the Skunk2 will be a much better choice for you. </TD></TR></TABLE>
Old 07-08-2007, 10:56 PM
PiMpIn's Avatar
Default Re: (dday00si)
AGREED
Old 07-09-2007, 12:45 AM
89hatcher's Avatar
planning on maybe the crower 404's
Old 07-09-2007, 11:08 AM
sneakysneaky's Avatar
Default Re: (89hatcher)
if you plan on cams that big go edelbrock.
Old 07-09-2007, 03:44 PM
89hatcher's Avatar
so with big cams and high revs edelbrock and with turbo cams skunk2
Old 07-09-2007, 07:04 PM
Mr. Badwrench
boostedcivicsir's Avatar
the vicx will hurt you down low. if you drive the car daily, stop light to stop light, and like to have fun there, use the blox or skunk 2, if you are going to race the car and dont care about anything below 4k i guess cause it isn a ls, go with the vicx.
Old 07-09-2007, 11:36 PM
89hatcher's Avatar
will the skunk2 have any problems when the revs get high?
Old 07-28-2007, 11:40 AM
tegsRcrack's Avatar
I have Sunk2 for my 97 LS and it hold higher revs just fine but I also havnt boosted it yet and so dont know how the final result will be. ( trying for 8 psi)
Old 07-28-2007, 11:42 AM
i ♥ snails
quicksilver1689's Avatar
i dont think it will be a dramatic difference between both in most f/i setups unless you have a full out drag car. Just go with the blox and call it a day, take the money you saved and throw it towards tuning.
Old 07-28-2007, 08:43 PM
89hatcher's Avatar
changed my mind about the LS now going LS/vtec turbo...will the skunk2 be efficient enough?
Old 07-28-2007, 09:00 PM
CELERITAS's Avatar
yeah people run stock intake manifolds making good power im sure this wont hold you back too far.
Old 07-28-2007, 11:26 PM
GetawayInMoscow's Avatar
Default Re: (CELERITAS)
Victor X
You aren't all motor....everything changes when you start cramming air into the combustion chambers. Victor X FTW regardless.
Old 07-29-2007, 02:31 PM
PiMpIn's Avatar
Default Re: (GetawayInMoscow)
Victor X
Old 07-30-2007, 10:49 AM
89hatcher's Avatar
so victor x for turbo and skunk2 for all motor.
Old 07-30-2007, 09:17 PM
PiMpIn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher &raquo;</TD></TR><TR><TD CLASS="quote">so victor x for turbo and skunk2 for all motor.</TD></TR></TABLE>
for your set up yes its the best idea the only other one tho maybe the BBK SSI it works great but its the same thing as the victor x basically just painted black.
Old 08-02-2007, 02:51 PM
89hatcher's Avatar
thanks..bbk is also cheaper than edelbrock...thanks again great help
kyden
02-25-2005 08:37 AM
js236
02-01-2005 08:53 AM
JDubya
12-08-2003 04:20 PM
MIKES
06-04-2002 07:32 PM
Quick Reply: which is best? victor x or skunk2 pro intake manifold?
