How much can it hold
Old Jul 10, 2007 | 01:49 AM
94turboeg's Avatar
Default How much can it hold
I have a 8.75 spring in my wastegate how much boost can it hold?
Old Jul 10, 2007 | 07:11 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: How much can it hold (94turboeg)
they say 2.5 x the base. but i have seen a .7 bar 38mm hold 34.
Old Jul 10, 2007 | 07:40 AM
1fastEK9's Avatar
what size is your wastegate ?
Old Jul 11, 2007 | 01:35 AM
94turboeg's Avatar
Default Re: How much can it hold (1fastEK9)
44m
Old Jul 11, 2007 | 03:20 AM
DaveF's Avatar
you can run infinite boost on it if you have the right setup. we run small springs and put alot of boost through our engines.
Old Jul 11, 2007 | 03:51 AM
Adriano's Avatar
Default Re: How much can it hold (dturbocivic)
With your typical boost controller it should hold about 21-23 before having issues. If you put one of those fancy boost controller that uses compressed air/co2 it will hold alot more.
Adriano
Old Jul 11, 2007 | 05:29 AM
Topdawgg's Avatar
what kind of boost controllers are you using for these high boost on low springs?
Old Jul 11, 2007 | 09:10 AM
1fastEK9's Avatar
Default Re: (Topdawgg)
greddy profec b-spec II
Aradin
Jan 28, 2012 03:00 PM
nychonda
Jul 1, 2009 04:37 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
