o2 sensor enabling question?
Old Jul 12, 2007 | 07:00 PM
the.hamburglar's Avatar
Default o2 sensor enabling question?
ok so this is kinda weird. i went to hook my my narrow band 02 sensor today because i was running it in closed loop all the time, but im not tuning it anymore so thats why i decided to enable it again. so i did this in crome and switched my wires back at the ecu so that my wideband was no longer giving the ecu a signal for datalogging. anyways i just wanted to check if my o2 sensor was working so i unplugged the white wire from the ecu and started up the car. i didnt get an engine code so then i went back to the map and checked to see if the narrow band was enabled. well it was and i have been driving around trying to get my 02 sensor check engine light to come on but i cant. any ideas? i just want to get it working
Old Jul 12, 2007 | 07:18 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: o2 sensor enabling question? (the.hamburglar)
usually the light will come on immediately from the heater not the sensor. (if i remember) plus, closed loop is when the o2 is used, if you have open loop enabled, it isnt going off of the o2.
Old Jul 13, 2007 | 11:23 AM
Default Re: o2 sensor enabling question? (boostedcivicsir)
ok so your saying if the white wire is cut then that wont throw a code, it will just run off the map? id like to use the narrow band so that i get better fuel economy. ya your right, always get the open/closed loop mixed up.
Old Jul 13, 2007 | 12:24 PM
Mr. Badwrench
it may not throw it immediately. but sooner or later throw a rich/lean code.
Old Jul 13, 2007 | 05:11 PM
ok, ill just leave it plugged in. once i plug in the o2sensor, white wire, i need to unplug the wideband signal from the sending unit to the ecu for data logging correct?
Old Jul 13, 2007 | 05:24 PM
jameelrose's Avatar
yup. 02 sensor takes a while to throw the code
o2 heater throws it instantly
Old Jul 13, 2007 | 05:49 PM
Default Re: (jameelrose)
oh ok thanks
JoshJosephKeith
May 4, 2009 04:38 PM
GSRalive
Aug 17, 2008 07:35 PM
Cutlass355
Apr 30, 2005 03:31 PM
92CiviCJdMMX
Feb 4, 2004 11:38 PM
DreamSpeed
Jan 13, 2002 11:29 PM
