what do bad rings look like?
Old Jul 11, 2007 | 06:06 PM
huge230's Avatar
Default what do bad rings look like?
Can you tell by looking at rings if they are bad or not?
Old Jul 11, 2007 | 06:11 PM
Joseph Davis's Avatar
Default Re: what do bad rings look like? (huge230)
Yes, but it takes a practiced eye.
Old Jul 11, 2007 | 06:13 PM
huge230's Avatar
Default Re: what do bad rings look like? (Joseph Davis)
Im going to replace anyway but is there anything i can look for? They look fine
Old Jul 11, 2007 | 06:46 PM
Yeah, I thought so too until a high end machinist schooled me on the subject.
His first criticism was the ring selection. The rings were moly coated, which is inappropriate for a big power turbo car that needs DLC or titanium nitrided rings. He pointed out how the black (moly) had been worn halfway up from the bottom side of the ring face (that seats against the wall) which was unacceptable for an engine that had seen 8K miles, whether or not we were spinning it at 9500 rpms. He also pointed out a couple of tiny spots where the moly had blown away on the ring face which causes blowby and more of the adjacent moly coat to chip away - which is why you aren't supposed to use moly rings on a big power car. Further, the second ring was not a napier design, ie inappropriate, and he also asked me a lot of questions on cylinder finish that I couldn't answer.
So, yeah, do you feel like you know enough to visually inspect your rings and know what you're looking at? I'm a decently bright guy, I got fifteen minutes of a master machinist's time complete with a visual aid, and I sure don't know half what I'd like to.
How about you glaze break your block and install the new rings?
Old Jul 12, 2007 | 04:35 AM
huge230's Avatar
they are being replaced but was just curious as to what to look for.. thanks for the reply
Old Jul 12, 2007 | 06:03 AM
I wish I had a one million megapixel camera and more knowledge, I'd do a write up for you. :/
Old Jul 12, 2007 | 06:35 AM
huge230's Avatar
i appreciate what you said, was just curious if there were some obvious things to look for
supersilverdc2
Dec 3, 2014 08:12 AM
PARADOX_sf
Jan 3, 2011 05:42 PM
siis2fast
Aug 12, 2004 04:47 PM
riceball777
Jan 17, 2004 09:41 PM
S13 slide
Jan 1, 2002 09:11 AM
