Question about Crome and 2 step
Old Jul 6, 2007 | 12:57 PM
speedy108's Avatar
Default Question about Crome and 2 step
My car is currently tuned on crome and I was wanting to add the 2 step to it.
Will my car have to be retuned to do this or are there adjustments in the map that can be changed with me just sending the ECU to the people that tuned it?
Old Jul 6, 2007 | 01:16 PM
SovXietday's Avatar
Default Re: Question about Crome and 2 step (speedy108)
Shouldn't need a retune, just needs to be put onto the ROM and setup for the RPM that you want.
Old Jul 6, 2007 | 03:14 PM
A.E Motoring's Avatar
Default Re: Question about Crome and 2 step (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't need a retune, just needs to be put onto the ROM and setup for the RPM that you want.</TD></TR></TABLE>
just has to add the option
Old Jul 22, 2007 | 07:53 AM
the.hamburglar's Avatar
sorry, but how does 2 step work?
Old Jul 22, 2007 | 08:03 AM
Boosted Chemist's Avatar
Default Re: Question about Crome and 2 step (the.hamburglar)
To my knowledge crome doesnt have a two step, just a launch control.
Old Jul 22, 2007 | 08:08 AM
Default Re: Question about Crome and 2 step (Boosted Chemist)
ya i never saw that either. i know my launch control works great...but what does 2 stepping do?
Old Jul 22, 2007 | 09:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ya i never saw that either. i know my launch control works great...but what does 2 stepping do?</TD></TR></TABLE>
I think adds retard and ends up making that popping noise instead of a fuel+spark cut. I think it allows you to spool off the line (antilag)
Old Jul 22, 2007 | 09:49 AM
ragethemachine86's Avatar
you can setup anti-lag with Crome. It requires you to go into the low cam maps and retard timing at/around the launch rpm. Only problem being it needs to be above your vtec rpm otherwise you will have issues if you go into those modified cells in the low cam.
I tried this the other day and built 4psi off the line @ 5800rpm using this technique. On a small turbo I'd say 10+psi is easily attainable.
Old Jul 22, 2007 | 10:10 AM
Default Re: Question about Crome and 2 step (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote">you can setup anti-lag with Crome. It requires you to go into the low cam maps and retard timing at/around the launch rpm. Only problem being it needs to be above your vtec rpm otherwise you will have issues if you go into those modified cells in the low cam.
I tried this the other day and built 4psi off the line @ 5800rpm using this technique. On a small turbo I'd say 10+psi is easily attainable.</TD></TR></TABLE>
I image vtec speed &gt;20 needs to be activated
Old Jul 22, 2007 | 11:04 PM
I image vtec speed &gt;20 needs to be activated</TD></TR></TABLE>
yes sir
Old Jul 23, 2007 | 07:53 AM
yes sir</TD></TR></TABLE>
What kind of timing do i run? -10 degrees at all the low cam boost cells &gt; vtec?
Old Jul 23, 2007 | 08:54 PM
JaredKaragen's Avatar
If you own a copy of CROME pro you would have the 2step feature...
It costs $165... I think. http://www.tunedwithcrome.com
Now... if you know someone with a registered copy....
Old Jul 24, 2007 | 05:05 AM
Default Re: Question about Crome and 2 step (JaredKaragen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaredKaragen &raquo;</TD></TR><TR><TD CLASS="quote">If you own a copy of CROME pro you would have the 2step feature...
Now... if you know someone with a registered copy....</TD></TR></TABLE>
F that, ill just use free crome till ectune is out for public use
Old Jul 27, 2007 | 04:52 PM
What kind of timing do i run? -10 degrees at all the low cam boost cells &gt; vtec?</TD></TR></TABLE>
i have all the cells necessary adjusted to 5degrees
wait you don't have CromePro?
Old Jul 28, 2007 | 05:10 AM
wait you don't have CromePro?</TD></TR></TABLE>
No crome pro, i was broke *** for a while and now im just going to get ectune when it comes out
s2knewb
Honda S2000
28
Jul 7, 2008 12:16 PM
trev0006
Other Make Vehicles
20
May 18, 2008 07:10 AM
lerner
11
Apr 29, 2006 05:47 PM
lightsleeper
Jan 25, 2006 06:58 PM
XxIchiBaNxX
Mar 9, 2005 07:38 AM
