hondata s300 tuners users, how do i raise up the 2 step
* B A N N E D *
Ok guys, my car is dyno tuned with hondata s300 and the 2 step is currently set up at 2500 which is too low. I want to be able to launch at 4k with drag radials. Anyone know how to raise the 2 step on the hondata s300. I dont want to mess up the tune. I just want to get step by step and how to do so without interrupting the tune
As long as you dont change any of the fuel or timing tables/ options the tune will be ok. Just change the number in the box from 2500 to whatever and you will be fine. Also make sure you upload it.
* B A N N E D *
Re: (SOHCD16y8)
can you show me where do I get to get to the 2 step option and how to upload it? I dont want to drive up to tuner since its hour away
turn ignition on and connect usb cable.
open sManager.
download your tune from the ecu. don't confuse this with downloading the datalogs.
click the parameters tab on top.
click launch control.
set your new limit number.
upload to ecu.
you're done.
open sManager.
upload to ecu.
you're done.
Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost »</TD></TR><TR><TD CLASS="quote">turn ignition on and connect usb cable.
open sManager.
upload to ecu.
you're done.</TD></TR></TABLE>
and then for the anti-lag settings just set that rpm 200 rpms lower than your 2step rpm and then like 15 for fuel and 10 for ignition.
open sManager.
upload to ecu.
* B A N N E D *
Re: (mike93eh2)
Why do I have to download the tune, This is the part I dont want to mess up. Shouldn't tune already be open once I open S manager
Re: (BALISTIKPNOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALISTIKPNOY »</TD></TR><TR><TD CLASS="quote">Why do I have to download the tune, This is the part I dont want to mess up. Shouldn't tune already be open once I open S manager</TD></TR></TABLE>
if the tune is saved onto your computer you an open it from your laptop and not download it from the ecu. change the settings and then upload and save.
youre not going to mess anything up lol..
* B A N N E D *
Re: (BALISTIKPNOY)
so I go to s manager, click on online, then click on download? then go parameter, launch control and set rev limiter then click online and finally click on upload?
Re: (BALISTIKPNOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALISTIKPNOY »</TD></TR><TR><TD CLASS="quote">so I go to s manager, click on online, then click on download? then go parameter, launch control and set rev limiter then click online and finally click on upload?</TD></TR></TABLE>
that is what we said..
