waste gate question
Old Jul 8, 2007 | 06:58 AM
integraRS-T's Avatar
Default waste gate question
if the spring is set at 7 psi does that mean thats all u can boost if so what do i have to boost higher change spring or somthin
Old Jul 8, 2007 | 01:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: waste gate question (rsracer)
with a 7 psi spring, without a boost controller, depending on where it is getting the boost reference, will be +- 1 - 2 psi.
with a boost controller, thats the least boost you can run.
Old Jul 8, 2007 | 01:27 PM
Default Re: waste gate question (boostedcivicsir)
so u sayin that thats the least u can run not the highest and what about a boost controler u need a manual one or digital
Old Jul 8, 2007 | 02:45 PM
Mr. Badwrench
7 psi spring = the MOST you can run with the gate hooked directly to a boost reference.
7 psi spring = the LEAST you can go down to with a manual or digital boost controller.
if you are asking these questions, you need to do a little research on this.
manuals are nice, they arent real consistent as they change as the air changes. ebc's are great but can get costly. best bet is a high low like the txs IF you have the high low boost tuned.
Old Jul 8, 2007 | 03:45 PM
b16a4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">7 psi spring = the MOST you can run with the gate hooked directly to a boost reference.
manuals are nice, they arent real consistent as they change as the air changes. ebc's are great but can get costly. best bet is a high low like the txs IF you have the high low boost tuned.</TD></TR></TABLE>
whats a txs ?
forgive me!
Old Jul 8, 2007 | 03:51 PM
Mr. Badwrench
Default Re: waste gate question (b16a4)
turbo x s. name brand.
sorry.
all good.
Old Jul 8, 2007 | 03:56 PM
Adriano's Avatar
When you have a "x" lbs spring, that means that that's the lowest amount of boost it will hold. You will need a boost controller (manual, electronic, digital) to raise the boost.
Adriano
alperx
Jul 11, 2011 10:57 AM
1990hondaHF
Jan 16, 2008 11:57 AM
94turboeg
Aug 13, 2007 12:08 AM
freeplay
Sep 4, 2003 06:38 PM
Nikos
Jul 10, 2002 08:46 AM
