I'm Tapping my oil pan and i have a quick question!
Ok so just to clarify, I should be tapping the pan in the middle of the deep end as high as i can right?
its for a y8
and then what size of fitting should i use....right now i have two fittings, a 90 degree with a 3/8 inch inlet and outlet (the fitting itself is like 3/4 of an inch but the actual hole is 3/8) and another fitting that is the same size but a 45 degree angle instead...do i need an even bigger size (cause i think i heard somewhere that i need a 1/2 minimum and that 5/8 is ideal...but that's friggin HUGE!)
....if you guys could post up some pics of your tapped oil pans i would be very helpful!
Thanks guys
patrick
its for a y8
Thanks guys
patrick
Re: I'm Tapping my oil pan and i have a quick question! (patrickd_21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrickd_21 »</TD></TR><TR><TD CLASS="quote">Ok so just to clarify, I should be tapping the pan in the middle of the deep end as high as i can right?
its for a y8
Yes, but be careful of the orientation in terms of bolt holes..you don't want a fitting in the way of a bolt.
Your return fitting should fit whatever line your using (duh) and the reason people use 1/2" inch is because it's only gravity fed, so you want as little resistance as possible, and for NO oil to get backed up in that line. Better safe than sorry
Here's a pic of mine..
its for a y8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrickd_21 »</TD></TR><TR><TD CLASS="quote">ok thatnks alot man
any one else have any input?</TD></TR></TABLE>
yeah dont put thread tape on flare fittings. only on pipe fittings. not directed at you but in the picture....
you could also pour four quarts (one gallon) of fluid, water whatever, in the pan see how high that is and just make sure its above that line then orientate the fitting for your setup.
Re: I'm Tapping my oil pan and i have a quick question! (agrn93ls)
that's a pretty good idea! thanks man
and i also have another question..is there like a standard in size for oil return lines...like is there a size that 90% of people use?
and should i use my 90 degree or the 45 degree fitting?
really just put your return fitting abt 1/2 from the top of the oil pan. don't worry if oil gets back into your line when the motor is off. a lot of people forget that there isn't much oil in the pan once the car gets started. no matter where you put the fiting at some point in time when ever you park your car facing downhill oil is going to run inside of there. just make sure there are no kinks in the line and your straight. installing a fitting in an oil pan isn't rocket science
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
LOL maybe that's why my oil return line always leaked. I thought I used Hondabond but apparently not
rdeezy78
11-02-2009 06:45 PM
BigMoneyP
05-29-2006 07:05 PM
