gt35r hp
Old Jul 10, 2007 | 08:47 AM
ant56's Avatar
Default gt35r hp
gt35r on gsr
with 9:1 cp pistons
eagle rods
p/p head
crower springs and retainers
balanced and blueprinted
victor x manifold
1000cc intectors
bosch 044 pump
-6 feed line from tank
also methanol injection
hoping for 550 at about 21 psi or so
what you guys think possible to do that
Old Jul 10, 2007 | 08:53 AM
TDCTyler's Avatar
Default Re: gt35r hp (ant56)
Tuning?
Old Jul 10, 2007 | 09:09 AM
boosted k20's Avatar
Default Re: gt35r hp (TDCTyler)
if its 81mm u will most likely need more than 21 psi. on 10 psi on my 81mm LS/VTEC im making 366. i say about 24-26 psi will get u 500+hp. 84mm will most likely make 500+ on 20 psi.
what cam and eachuast setup r u runing?
Old Jul 11, 2007 | 06:45 AM
ant56's Avatar
Default Re: gt35r hp (boosted k20)
type r cams an a three inch downpipe open dump tube on wastegate
crome pro as tuning software
Old Jul 11, 2007 | 02:40 PM
Supacharge's Avatar
should do it. i made 496whp @ 18psi on 93 octane. 592whp @ 22 psi on c16. i have a very similar setup; im 85mm bore, ctr cams, same intake mani. g'luck with doing it!
Old Jul 11, 2007 | 04:24 PM
quik sol's Avatar
chromes all fine and dandy, but with the kind of build up, why wouldn't you use something better? I have no issues with chrome, but I always have used it with 300 hp or less cars.
Old Jul 11, 2007 | 05:35 PM
dannydos's Avatar
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">chromes all fine and dandy, but with the kind of build up, why wouldn't you use something better? I have no issues with chrome, but I always have used it with 300 hp or less cars.</TD></TR></TABLE>
its crome not chrome....
Old Jul 11, 2007 | 05:48 PM
boostismycrack's Avatar
E-thug
My setup is very similar (84.5mm tho) and made 448 hp @14psi on pump. I think 550 is realistic at 21psi give or take a pound...
Old Jul 11, 2007 | 06:20 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">if its 81mm u will most likely need more than 21 psi. </TD></TR></TABLE>
81mm LS/VTEC with GT35R, 535-540 whp at 20 psi (low boost setting) on Torco 110.
I have the car in question strapped to the dyno five feet from me right now for a retune with a snowperformance alky/water injection kit. So far I've knocked off a 565 and a 554 at 20 psi (low boost setting) with alky/water, sitting here with my thumb up my *** while the boys swap out a bunk distributor, hoping to do a bit better.
FYI, the only real difference I see between this car and yours are the cams. This one has a set of Brian Crower's which are a noticeable difference over GSR/ITRs, and pretty much made the deal. Personally, if this were my own car, I'd run GSR/ITR cams and turn the boost up a couple more psi to make 550 and save a few bucks in the process. Do whatever you feel you must on your car.
Old Jul 11, 2007 | 06:26 PM
quik sol's Avatar
sorry, half awake when typing earlier...and now.
Also, is it sleeved?
Old Jul 12, 2007 | 05:53 AM
Turbo-charged's Avatar
pump gas, i think the bigger power one was 17psi
my personal 35r car made 555@18psi and 616@25psi. power went down with any more boost. .63 t3 with a hair of compression
Old Jul 12, 2007 | 06:23 AM
SPOOLINmatt's Avatar
Default Re: (Turbo-charged)
crome will support 600hp no problem.
Old Jul 12, 2007 | 07:39 AM
Supacharge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">
my personal 35r car made 555@18psi and 616@25psi. power went down with any more boost. .63 t3 with a hair of compression</TD></TR></TABLE>
sounds like you have higher compression w/ those numbers. what is your c/r? the highest dyno i have seen for a 35r (and im sure there are some higher #s somewhere) was at RLZ. a car made 651whp @ 27psi on stock fuel system and 1000cc injectors. still dont know how it did that. mine ran out of fuel at 22 psi. gota upgrade lines to go higher now
Old Jul 12, 2007 | 08:02 AM
98vtec's Avatar
moderator emeritus
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">crome will support 600hp no problem. </TD></TR></TABLE>
depends on how much timing you REALLY need to take out.
Old Jul 12, 2007 | 08:05 AM
Default Re: (Supacharge)
yes i stated mine was with higher compressoin. the graph was a 9:1 motor
Old Jul 12, 2007 | 08:16 AM
Topdawgg's Avatar
im at 9.0:! and i have the .82
I want 600 but im afraid im gonna run out of fuel up there also...
stock lines, walbro 255 and RC 1000's
made 442 on 91 octane creeping up to 20 psi...
just street tuning only, nothing touched for ignition... etc
only reving to 8200
84mm LS/Vtec
Old Jul 12, 2007 | 08:25 AM
Doostur's Avatar
Default Re: gt35r hp (Supacharge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supacharge &raquo;</TD></TR><TR><TD CLASS="quote">should do it. i made 496whp @ 18psi on 93 octane. 592whp @ 22 psi on c16. i have a very similar setup; im 85mm bore, ctr cams, same intake mani. g'luck with doing it!</TD></TR></TABLE>
Exactly what im hoping for!
Old Jul 12, 2007 | 10:52 AM
Supacharge's Avatar
Default Re: gt35r hp (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">im at 9.0:! and i have the .82
only reving to 8200
84mm LS/Vtec</TD></TR></TABLE>
im only 8.8:1 ... it will be cutting it close. i rev to 9k right now. as for ignition, i know some people get stock ignition to support that power. mine wouldnt. but what was really cool is that i made 542 whp @ 21 psi and then 592 whp @ 22 psi with only the ignition change (MSD) do you have stock cams still? i swear by CTR cams. ive seen huge power gains. those arent the only ones though; to each his own. we have the same fuel set up, so it'll be close! unless your car is a freak. **** happens
Old Jul 12, 2007 | 11:52 AM
ant56's Avatar
im upgradeing the fuel system with -6 fuel lines and a bosci=h o44 pump in tank that will support we are hoping for about 600hp
as ignition we are going to try stock and if it starts to break up we will tighten the plug gap and if that doesnt happen then ill install the msd ignition in and go from their
Old Jul 12, 2007 | 12:47 PM
BfromSD's Avatar
Dont use Crome if you are gonna be daily driving it with big hp# or injectors. I to have a similar setup as yourself, t3/04 60trim 63a/r turbo, LsV, rods, pistions, IM, rc 1000cc injectors, duel valve train, b16 cams.
When I had my car dyno'ed tuned on Crome at shawn Church we were having trouble with getting it to run smooth. After a while of him being frustrated he plugged in his hondata s300 to make sure all the troubles were within the ecu. 5 pulls later we were doing 400hp making power to 8800rpms and their was still refining to do.... Back to the Crome and nothing but problems, it took like 10 or more pulls and more psi to just get to the 400hp mark and it would not rev. past 8000. It still dosent rev were I need it to and also dont idle like the hondata did eather. save up like im doing and get the hondata or AEM, I know their pricy for the wages$ most us Honda drivers are makes but it is WELL worth it in my opion.
Old Jul 12, 2007 | 07:31 PM
Default Re: gt35r hp (BfromSD)
Sounds like Shawn was unfamiliar/inexperienced with Crome. Frankly, the script setup for Crome is a messy clusterfuck; I found a good combo of scripts/version of Crome and refused to fool around with anything new for six months at a time because I liked **** that ran right and didn't make me look like an idiot.
The poor idle is - was - a common complaint. There are ways around it, but it was something you had to drop a minute on. Recent versions of Crome have good control of the IACV and is comparable to Hondata in terms of idle control.
Old Jul 12, 2007 | 10:00 PM
Supacharge's Avatar
Default Re: gt35r hp (Joseph Davis)
i'll agree with the "off idle". when i was on crome, mine "loped". it wasnt a problem really, and never hurt anything. it sounds like a big *** cam was in it. never stalled or anything.
also ... did any of you crome guys have any problems with this: if you come out of boost hard and hit the break while going into neutral at the same time .... did the car die or almost die? it was like it wanted to stall when the rpm dropped that quickly. but it didnt do it all the time. anyhow, with hondata, that hasnt been an issue at all. also could have been some fuel differences from the tuner. just wondering what you guys thought ...?
Old Jul 13, 2007 | 12:39 AM
Mykizism's Avatar
wtf
Old Jul 13, 2007 | 12:41 AM
GiNuWiNe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supacharge &raquo;</TD></TR><TR><TD CLASS="quote">i'll agree with the "off idle". when i was on crome, mine "loped". it wasnt a problem really, and never hurt anything. it sounds like a big *** cam was in it. never stalled or anything.
also ... did any of you crome guys have any problems with this: if you come out of boost hard and hit the break while going into neutral at the same time .... did the car die or almost die? it was like it wanted to stall when the rpm dropped that quickly. but it didnt do it all the time. anyhow, with hondata, that hasnt been an issue at all. also could have been some fuel differences from the tuner. just wondering what you guys thought ...?</TD></TR></TABLE>
same problem i had, i raised my resume idle and it helped a little.
Old Jul 13, 2007 | 01:50 AM
Topdawgg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BfromSD &raquo;</TD></TR><TR><TD CLASS="quote">Dont use Crome if you are gonna be daily driving it with big hp# or injectors. I to have a similar setup as yourself, t3/04 60trim 63a/r turbo, LsV, rods, pistions, IM, rc 1000cc injectors, duel valve train, b16 cams.
When I had my car dyno'ed tuned on Crome at shawn Church we were having trouble with getting it to run smooth. After a while of him being frustrated he plugged in his hondata s300 to make sure all the troubles were within the ecu. 5 pulls later we were doing 400hp making power to 8800rpms and their was still refining to do.... Back to the Crome and nothing but problems, it took like 10 or more pulls and more psi to just get to the 400hp mark and it would not rev. past 8000. It still dosent rev were I need it to and also dont idle like the hondata did eather. save up like im doing and get the hondata or AEM, I know their pricy for the wages$ most us Honda drivers are makes but it is WELL worth it in my opion.</TD></TR></TABLE>
ummm ok... what constitutes big power or big injectors?
Im daily driving my 1000's on my 84mm LS Vtec street tuned with crome... makin 442 on pump gas... and works great.....
Id say get a new tuner....
