tapping oil pan
Old Jul 11, 2007 | 05:34 PM
civicsaremean's Avatar
Default tapping oil pan
where is the proper place to tap ur oil pan?????? the best place to prevent kinks!
Old Jul 11, 2007 | 05:36 PM
RCautoworks's Avatar
Default Re: tapping oil pan (civicsaremean)
Place manifold on the car, put turbo onto manifold, mock up line and make marks, get it as high as possible. And don't tap it so you can't put a bolt or a nut into the oil pan
Old Jul 11, 2007 | 05:40 PM
aarontrini85's Avatar
Default Re: tapping oil pan (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">And don't tap it so you can't put a bolt or a nut into the oil pan </TD></TR></TABLE>
ive done that before
didnt leak though
Old Jul 11, 2007 | 07:36 PM
esedulerp5tenin's Avatar
Default Re: tapping oil pan (aarontrini85)
put the downpipe on also, cuz my first attempt at a return line wrapped around the DP so it drained into the deep part of the pan, til i realized i could run it STRAIGHT down from the turbo. it drains in the shallow portion, but i've had no problems so far
Old Jul 12, 2007 | 10:40 PM
Default Re: tapping oil pan (esedulerp5tenin)
u know how the oil pan's shape is like an upside down "L". if i tapped it near the oil pan curve where it forms that L shape. is that a propper place?
Old Jul 13, 2007 | 02:55 AM
help!!!!
Old Jul 13, 2007 | 03:06 AM
Default Re: (civicsaremean)
i was told to tap high like as high as you can.
i dont see what the issue would be going that low but i just did what i was told though rather then finding out what the posible issue might be
Old Jul 14, 2007 | 10:35 PM
anyone got their oil drain setup on PICS?????
Old Jul 14, 2007 | 11:56 PM
What do you need pics of ? Its just a hole in the pan.
Old Jul 15, 2007 | 07:21 AM
stealthmode62's Avatar
Default Re: (RCautoworks)
The first response by RCautoworks is all you need to know. Still trying to guess or go off of other peoples' pictures is asking for trouble. Don't rush it, and do it right.
Old Apr 4, 2008 | 12:25 PM
hbcrazy88's Avatar
Default Re: (stealthmode62)
hey stealthmode, i bought your t3 oil line kit for my honda. does that come with the part that i need for the oil pan or do i still need to buy that part. and if i do could you direct me in that way.
Old Apr 4, 2008 | 03:33 PM
Default Re: (hbcrazy88)
Holy back from the dead batman. You don't need anything else. Here's how the kit taps into the pan.
http://stealthmodeperformance....shtml
teamV eg
Jun 30, 2006 11:58 AM
crx_pimp
Sep 1, 2005 04:34 PM
Novtecdohc
Aug 31, 2005 04:29 PM
Layziebtnh055
May 16, 2004 10:09 AM
Steve91
May 29, 2003 08:43 AM
