dsm 450 injectors
Old Jul 9, 2007 | 12:41 AM
sasinorm01's Avatar
Default dsm 450 injectors
i have used the search button to find a DIY thread but cant find it... need that link if anyone know what i need to install the dsm injectors into a d16z6
Old Jul 9, 2007 | 06:59 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: dsm 450 injectors (sasinorm01)
the injectors go in the same way, here is the resistor box install:
https://honda-tech.com/zerothread?id=517274
Old Jul 9, 2007 | 07:18 AM
pjr710's Avatar
Default Re: dsm 450 injectors (boostedcivicsir)
a lot of people splice their honda injector clips. isnt it possible to connect dsm injectors with the stock honda clips as long as that blue square comes out of the middle?
Old Jul 9, 2007 | 08:03 AM
BDogggUT34's Avatar
Default Re: dsm 450 injectors (pjr710)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">a lot of people splice their honda injector clips. isnt it possible to connect dsm injectors with the stock honda clips as long as that blue square comes out of the middle?</TD></TR></TABLE>
Yes thats the way i did it. If you take the blue piece out, you can push the pins back and out of the clip, then insert the new ones from the resistor box into the clip. Really easy!!
Old Jul 9, 2007 | 12:52 PM
sasinorm01's Avatar
well i have a d16z6 in a 89 ef sedan...so i think i already have the resistor box ....now the dsm injectors dont sit like the factory injectors do in the intake manifold is that ok?
Old Jul 10, 2007 | 10:18 PM
sasinorm01's Avatar
well anybody...and where do i get those clips fot the dsm injecetors
Old Jul 10, 2007 | 10:29 PM
almostboostedgsr's Avatar
Default Re: (sasinorm01)
go to http://www.homemadeturbo.com simple as that.
Old Jul 12, 2007 | 03:08 AM
BDogggUT34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">well i have a d16z6 in a 89 ef sedan...so i think i already have the resistor box ....now the dsm injectors dont sit like the factory injectors do in the intake manifold is that ok?</TD></TR></TABLE>
Bore out the bushings just a little so they can sit flush. I used the closed end of a wrench, put the soft and hard bushings inside, and bored them out a little with my dremel. They sit flush and have no leaks at all.
Old Jul 12, 2007 | 06:43 AM
twkdCD595's Avatar
Default Re: (BDogggUT34)
the clips are just a standard obd1 clip... I have a set if you need them... just pm me your address and I will mail you some if you want. It will be my good deed for the week.
Old Jul 12, 2007 | 07:26 AM
dpetro1's Avatar
Default Re: (twkdCD595)
http://www.homemadeturbo.com/t....html
there ya go. complete dsm injector install
ceemarun
Aug 7, 2015 05:21 PM
h23vtec_dc2
Mar 31, 2014 09:53 PM
SiR99
May 29, 2006 09:57 PM
khmboostedeh2
Mar 29, 2005 07:45 PM
boostedblack99
May 2, 2003 04:42 AM
