what can I reasonably expect to make for reliable power on this setup?
I am new to the turbo D series realm and am going to pick up my engine next week. I am curious to know what I can make reliably for horsepower once the engine is tuned with hondata. To start with I will be using a Vafc.
Here are the specs:
d16z6
ARP head studs
steel headgasket
eagle rods
JE pistons
All new OEM bearings
Cast DRAG manifold
T3
FMIC
Venom fuel rail
750cc injectors
FPR
stage 4 clutch
38mm wastegate
The motor was being tuned and on the first pull the clutch gaveway but the car made 258 whp and 248tq at 4200rpms on 13psi.
What can I safely run for boost on this setup with an AFC tune? And how about hondata on the dyno?
Just curious what I am getting myself into here... I may run a race gas map, what would be safe for 93 octane, and what numbers could I get out of this engine tuned for c16 with hondata?
thanks
-Marc
Here are the specs:
d16z6
ARP head studs
steel headgasket
eagle rods
JE pistons
Cast DRAG manifold
T3
FMIC
Venom fuel rail
750cc injectors
FPR
stage 4 clutch
38mm wastegate
thanks
-Marc
Re: what can I reasonably expect to make for reliable power on this setup? (LShatchboy)
why tune it twice. hondata is only 175 dollars, vafc isnt a very good tuning solution. how are u tuning for ignition?
H23ludedude
05-05-2002 09:03 PM
