engine rpm goes up and down over 2000 rpm
hello.
i have a crx vtec turbo
b16a1 with t04e itr cams 550cc injector's and so on,
when i rev the engine up and stand still, under 2000rpm everything is normal, but when i go over 2000 rpm the engine goes up and down, about 500rpm. i think i don't have a vacuum leek, and the idle is perfect. i have it tuned and when i look at the map, the fuel is almost like original,
please post everything that you can think of. i have tried change the fast idle and the eacv, spark plugs ignition wires are fine,
Modified by anton_ at 3:28 AM 7/15/2007
Modified by anton_ at 3:31 AM 7/15/2007
Re: engine rpm goes up and down over 2000 rpm (anton_)
rewrite that so people can understand what the hell you just said and maybe youll get some help... spell check is your friend
hey i have the same problem with my gsr turbo i think is somthing to do with tps on the throttle body mines only happen sometime still dont know wat to do sorry
Re: engine rpm goes up and down over 2000 rpm (blueintegra)
my englisch is not so good. sorry.
hmm maybe i can try with another tps.
i have a vafc to så i can se the tps position, and when i drive around it also goes up and down. from 12% to 7%
also when i cruse around in 80mph the car goes down and "engeine brake" when it does that the tps get steady,
sorry for the bad eng, iam gonna make a movie so you can se and hear the problem
I have the same problem as you. We data logged and at anything under 10% throttle my injectors were randomly shutting off. The setup is LS turbo, RC 550 injectors, and hondata s200. Still don't know what the problem is though.
Re: engine rpm goes up and down over 2000 rpm (8herout)
sometimes the cut off is from the idle cut off seting in yer ecu... and from not having the idle valve plugged in and the tps not being calibrated correctly... but most of the time it can be eliminated with raising the idle fuel cut off setting
Re: (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">sometimes the cut off is from the idle cut off seting in yer ecu... and from not having the idle valve plugged in and the tps not being calibrated correctly... but most of the time it can be eliminated with raising the idle fuel cut off setting</TD></TR></TABLE>
This may be a stupid question but does Hondata s200 have that idle fuel cut of setting your talking about?
Re: (8herout)
i have read that it can be something that's called "fuel-cut" and if you have a apexi vafc the fulecut can be changed? is that right? if so, how can i make it so it doesn't cut the fuel on high vacuum?
Harrold
02-11-2008 02:38 PM
cbspeedspot
08-29-2005 09:56 AM
