good cam for itr valvetrain??
im currently using oem itr springs and omni ti retainers and was thinking about getting some new cams as im getting tired of these gsr's.
i see theres been a lot of cam comparisons with good results, but which ones can i use with my valvetrain? my rev limit is currently at 8700, and my motor is an 84x89 pr3 head and blox im. t3 60-1 on a mini ram/3" turboback
itr/ctr.....although
i have never tried that combo, i know people have made it work. i went from gsr's to maz/ipg cams
i know they gave me a bit more in the middle. it is kinda hard to compare the cams w/ last year as i was 84mm b16 crank.
stick to the itr's if already you have them but your next upgrade would be to get rid of that intake manifold if you have an oem type r mani then use that we've done over and over testing between blox/skunk2/itr/ skunk2 show's gains over the itr but for some reason blox mani lost 14whp over the itr's so if your lookin for that easy additional hidden power that would be a definate upgrade,down grade depending on your position
Chipped B6
15
Feb 3, 2009 11:36 PM
