boosting more
Old Nov 9, 2007 | 06:19 PM
Eklsv-t's Avatar
Default boosting more
I have drag kit on my lsvtec ek hatch. I currently running 38mm Tial wastegae with stock psi spring boosting 6psi. Can I raise the boost if I change the wastegate spring to 10psi without boost controller?? Im tuned with hondata s300 and hallman manual caused me boost spike ,almost blowing my motor. So if I purchase this 30 dollar part from Tial, .7bar, Im hoping to boost 10psi. I would bring my hondata s300 to hondata to install boost by gear but I need my car
Old Nov 9, 2007 | 06:44 PM
moores55's Avatar
Default Re: boosting more (Eklsv-t)
You can buy the .7 bar spring if you want to boost more. but you will need a re-tune with the higher boost level.
Old Nov 13, 2007 | 04:53 PM
JaredKaragen's Avatar
Default Re: boosting more (moores55)
MBC's tend to cause spikes when under certain conditions.
there is a chance the MBC itself caused the spike and another form of BC would do the job nicely, I always say; it is better to have a lower BASE spring rate, that way you have a low failsafe zone, and when the spring gives you issues at higher boost levels, then upgrade to a stiffer spring as needed.
you should be ok with the 10psi spring though.
civintegra
Mar 4, 2013 04:11 PM
GReddy SI
Mar 2, 2010 08:10 PM
91integraLSVTEC
Oct 21, 2009 11:09 AM
powerdbygarrett
Jul 3, 2008 01:50 PM
92jdmhatch
May 4, 2004 12:10 AM
