ecu tuning
i have a half *** b16t set-up and im pretty sure its tuned on turbo edit. is there a place online i can down load that program on my laptop and if there is am i able to tune it by myself (if i know what im doing) with my laptop with out having to burn anything on to the chip??
thanks
thanks
I use an Ostrich: Moates.net you can reflash it while the motor is running.
another option is the homebrew RTP.
The best thing u can do with what you have is make sure you have datalogger code set-up, and u can log from your OEM ecu.
im reading all this helpful information and im wondering this b16t is in a 95 civic dx and i know its a obd1 ecu and like i said im pretty sure its tuned on turbo edit. now im readind that i can retune it but how do i get the turbo edit software on my laptop if at all possible??, and what other equipment would i need if i was to tune it with out burning another chip?
thanxs guys
thanxs guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaredKaragen »</TD></TR><TR><TD CLASS="quote">I use an Ostrich: Moates.net you can reflash it while the motor is running.
The best thing u can do with what you have is make sure you have datalogger code set-up, and u can log from your OEM ecu.</TD></TR></TABLE>
this looks like good info but can you break it down for me a lil more about the datalogger and the code set up and by log do you mean store the new map??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr »</TD></TR><TR><TD CLASS="quote">im reading all this helpful information and im wondering this b16t is in a 95 civic dx and i know its a obd1 ecu and like i said im pretty sure its tuned on turbo edit. now im readind that i can retune it but how do i get the turbo edit software on my laptop if at all possible??, and what other equipment would i need if i was to tune it with out burning another chip?
thanxs guys
If it is on a OBD1 ecu, it cannot be tuned with turboedit. I would suggest you take it to a tuner to have it tuned and really find out what is going on with it. Then you know what is on the ecu and can set it up accordingly to datalog.
thanxs guys
</TD></TR></TABLE>If it is on a OBD1 ecu, it cannot be tuned with turboedit. I would suggest you take it to a tuner to have it tuned and really find out what is going on with it. Then you know what is on the ecu and can set it up accordingly to datalog.
so you mean to tell me that if its an obd1 then its not turbo edit, correct??
then my next guess would be uberdata can uberdata be used for obd1 ecu and if so can it be tuned on my laptop with out burning a chip??
again thanks
again thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr »</TD></TR><TR><TD CLASS="quote">so you mean to tell me that if its an obd1 then its not turbo edit, correct??
again thanks
You can't tune it on your laptop without burning a chip unless you have an ostrich. I would take a look at the FAQs listed at the top of the page. There are tons of links that will help you out.
again thanks
</TD></TR></TABLE>You can't tune it on your laptop without burning a chip unless you have an ostrich. I would take a look at the FAQs listed at the top of the page. There are tons of links that will help you out.
again thanks
The only way it was tuned on TurboEdit is if the original creator of TurboEdit tuned it...he did have an OBD1 Version that he never released to the public and he was from Kansas, so...
again thanks
</TD></TR></TABLE>The only way it was tuned on TurboEdit is if the original creator of TurboEdit tuned it...he did have an OBD1 Version that he never released to the public and he was from Kansas, so...
