Getting basemap to work? (crome)
Old Nov 10, 2007 | 01:42 PM
Bizarre's Avatar
Default Getting basemap to work? (crome)
Alright so hopefully I have all the details in here.
I'm using a p06 converted to vtec. I followed Xenocron's how to on making your own basemap and I pretty much followed it to the t so i'm not exactly sure what I did wrong. So what I did, took original fuel and ignition maps and copied them into the p30, disabled the checksum, added boost tool, etc... Motor is pretty stock; a b18c with just eagles and wiseco pistons using precision 880cc injectors and a gm 3bar. Now when I upload the map I cannot get the car to run, it starts and then just dies! If I try to give it gas it bogs down and struggles to rev up. I've been trying to play with the advanced fuel multiplier but nothing has helped. I loaded a b16 map with a similar set up from xenocron's bin dump and it runs perfectly fine with it. So i'm not sure what I did wrong. Any help would be appreciated! Thanks!
Note: I tried starting off with just a p72 basemap and it does the exact same thing.
Old Nov 10, 2007 | 04:37 PM
base-op.1320's Avatar
Default Re: Getting basemap to work? (Bizarre)
It sounds like you need to put the stock injectors back in it and stock map sensor get it running with the p72 basemap all stock, then switch to your turbo basemap with stock map sensor and injectors. Then change the injectors and adjust accordingly then add the 3 bar map sensor. It is always easier to make single changes at a time when possible so you can make all your adjustments one at a time. Also how sure are you they are 880cc injectors and do you have a wideband to check afr at idle.
Old Nov 10, 2007 | 04:42 PM
Ovrbst_T66's Avatar
Sounds like you need fuel.Post your bin or try and add 10% of fuel to the whole low cam and high cam map.I have a few bins that may also work for you.
Old Nov 11, 2007 | 10:36 AM
Bizarre's Avatar
Default Re: Getting basemap to work? (Ovrbst_T66)
Hey thanks guys for your help. I figured out the problem. It was such a silly mistake
Old Nov 11, 2007 | 01:02 PM
you should still explain what happened for future reference
Old Nov 11, 2007 | 02:33 PM
Bizarre's Avatar
Default Re: Getting basemap to work? (base-op.1320)
While adjusting the injector offset I had actually put a decimal point in front of the value. So instead of it being 85 it was .85, thus causing the car not to run. Seriously, after i sat back and went through everything thoroughly I finally noticed this stupid error
Old Nov 11, 2007 | 05:21 PM
187Chor's Avatar
so is it running fine now?
Old Nov 12, 2007 | 06:00 AM
Bizarre's Avatar
Default Re: (187Chor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 187Chor &raquo;</TD></TR><TR><TD CLASS="quote">so is it running fine now?</TD></TR></TABLE>
Well it's running fine as in idling fine. I had found the problem so late at night I didn't want to take it out for a drive. But everything should be good now and it's ready to be tuned. Thanks everyone
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
Joseph Davis
Feb 7, 2007 12:18 PM
timisyourfriend
10
Jan 6, 2006 07:31 AM
Si Shane
Apr 9, 2005 08:23 AM
B20fun
Oct 30, 2003 10:54 PM
