tune every psi???
Old Nov 15, 2007 | 06:01 PM
turbo boost's Avatar
Default tune every psi???
when tuning a boosted engine...is it best to tune every psi or close to it untill the desired power?...or if u want to run the car on 14.5 psi can u just stick that spring in and tune it?
Old Nov 15, 2007 | 06:05 PM
A BOOSTED CRX's Avatar
Default Re: tune every psi??? (turbo boost)
huh? are you dyno tuning it, or just setting the spring to the desired psi..whats your question?
Old Nov 15, 2007 | 06:06 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">when tuning a boosted engine...is it best to tune every psi or close to it untill the desired power?...or if u want to run the car on 14.5 psi can u just stick that spring in and tune it?</TD></TR></TABLE>
If you want to run different boost levels, then I would say it is important to tune each stage that you want to run. If you are just going to run a 14.5 psi spring all the time. Then you can't really tune any lower than that at WOT, so only if you are going to vary the boost with a boost controller will you worry about tuning the whole range so to speak.
Old Nov 15, 2007 | 06:10 PM
Default Re: tune every psi??? (93turbo16)
ok...thats what i was asking...so if i want to use the 1 bar spring then ill just put it in and get it tuned on that.....i thought every psi had to be tuned the whole way up to ur final psi...thats y i asked
thanks
integraRS-T
Jul 8, 2007 03:56 PM
teddy_dc2
Aug 6, 2006 07:10 AM
ochsy03
Nov 4, 2005 07:33 PM
siis2fast
Aug 28, 2005 08:21 PM
White_EK49
May 24, 2005 09:46 PM
