Turbo Surge
Old Nov 13, 2007 | 06:17 AM
96 GSR-T's Avatar
Default Turbo Surge
Just got my car all put together and I went out to do a little crusing, turbo starts to build boost at 4100 in 2nd gear, every time I let off the gas promptly I am getting the fluttering sound coming out the turbo, using a Tial 50mm BOV, one thing I noticed different about my car versus my friends car also running a 50mm BOV is when he presses the gas and lets off at idle his BOV moves in and out where mine is stationary, I have good vacumn and the line is Tee'd off anohter vacumn source, should I try to give it an independent vecumn source off the manny or do i have other problems?
Old Nov 13, 2007 | 06:39 AM
Riake's Avatar
Default Re: Turbo Surge (96 GSR-T)
Try a new source with a larger vacuum line. If that doesnt work buy a less stiff spring. How much vacuum do you pull?
Old Nov 13, 2007 | 07:11 AM
96 GSR-T's Avatar
Default Re: Turbo Surge (Riake)
550 mmhg @ idle, more when lugging and then letting off the gas
Old Nov 13, 2007 | 08:01 AM
TiAL's Avatar
which spring do you have?
you need a -11
Old Nov 13, 2007 | 09:39 AM
96 GSR-T's Avatar
Default Re: Turbo Surge (TiAL)
that is what I have, isnt that the Honda Std. spring? I bought it from Neukin over the summer and we did the math before I ordered it, I know the sound is surge even though I have only heard 1 other Tial BOV incar before, I am going to delete the Tee and run an independent barb fitting just for the BOV to see if it helps.
Old Nov 13, 2007 | 09:53 AM
White Smoke's Avatar
i my honda
Global Mod
Is your line hooked up before of after the throttle body? It should be hooked up AFTER it, on the intake manifold.
Old Nov 13, 2007 | 01:01 PM
96 GSR-T's Avatar
Default Re: Turbo Surge (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Is your line hooked up before of after the throttle body? It should be hooked up AFTER it, on the intake manifold.</TD></TR></TABLE>
after, on ports on back of victorx, when I added the bigger line earlier I noticed I stuck it on a really small barb, moved my boost controller to that barb and the BOV to the bigger barb, hope this fixes it.
1DayIllBFast
Jul 10, 2009 06:22 AM
Jupe
Jul 8, 2007 02:42 PM
t57b18
Apr 5, 2007 06:19 AM
dustin
May 9, 2005 12:12 PM
bluels-t
Sep 27, 2004 01:45 PM
