turbo/muffer?
Old Nov 10, 2007 | 07:48 AM
mma82's Avatar
Default turbo/muffer?
what muffler do you all suggest to get w/drag turbo kit w 3"down pipe and exhaust on 96 civic coupe with b18c?
Old Nov 10, 2007 | 07:57 AM
Schister66's Avatar
Man U FTW
anything thats straight through...i can't remember what kind i have, but its a 3" inlet/ 4" tip Magnaflow....it wasn't too pricey and i like it. I would suggest a resonator with it though
Old Nov 10, 2007 | 08:07 AM
mma82's Avatar
Default Re: (Schister66)
thanks man. what do you think about the Apexi N1 muffler with the resonator?
Old Nov 10, 2007 | 08:09 AM
Schister66's Avatar
Man U FTW
I'm not familiar with it...is it a chambered muffler or straight through?? What is the inside diameter??
I wouldnt go any smaller than 3" because it'll be a bottleneck on your exhaust
Old Nov 10, 2007 | 08:26 AM
mma82's Avatar
80mm inlet and 115mm tip for turbocharged vehicles. straight tuned
Old Nov 10, 2007 | 08:27 AM
mma82's Avatar
Default Re: (mma82)
straight through i mean
Old Nov 10, 2007 | 09:21 AM
BlackT5's Avatar
Old Nov 10, 2007 | 12:15 PM
Blown90hatcH's Avatar
Default Re: turbo/muffer? (mma82)
burns
Old Nov 10, 2007 | 02:47 PM
blitz23's Avatar
kakimoto muffler. deep sound and burbly. not ricey
Old Nov 10, 2007 | 03:20 PM
roachsboosted16's Avatar
ive got 2.25", and i went to ebay with my muffler, a 2.25" straight thru, and it works perfect. my exhaust= free 2.25" stainless, $80 hi flo cat, and $15 chrome ebay mufflr, = $95 custom exhaust that looks beautiful.
Old Nov 10, 2007 | 03:28 PM
Tippyman's Avatar
Default Re: turbo/muffer? (roachsboosted16)
WTF are you talking about? A turbo is a muffler.
Old Nov 10, 2007 | 03:29 PM
Default Re: turbo/muffer? (Tippyman)
(end of exhaust muffler) u knew wat we were talkin about
Old Nov 10, 2007 | 03:34 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">(end of exhaust muffler) u knew wat we were talkin about</TD></TR></TABLE>
Sarcasm: 1: a sharp and often satirical or ironic utterance designed to cut or give pain
2 a: a mode of satirical wit depending for its effect on bitter, caustic, and often ironic language that is usually directed against an individual
b: the use or language of sarcasm
Old Nov 10, 2007 | 04:02 PM
im glad u can operate a dictionary
Old Nov 10, 2007 | 04:29 PM
Bailhatch's Avatar
hooker max flow is one of my favorites. mild steel, straight through, black & likely the quietest 3" perf core muffler out there (besides the borla stainle$$)
Old Nov 10, 2007 | 06:05 PM
mma82's Avatar
i asked about the apexi n1 piping and muffler?
Old Nov 11, 2007 | 04:23 PM
TDogg Teg's Avatar
I got a Kteller turbo muffler. Stainless steel. Comes 5x8 with 4" stainless steel tip, angle slant cut.
http://www.kteller.com
Old Nov 11, 2007 | 06:53 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mma82 &raquo;</TD></TR><TR><TD CLASS="quote">i asked about the apexi n1 piping and muffler?</TD></TR></TABLE>
you can do a custom setup and use the 3" universal n1. kinda pricey though. apexi doesnt make a full 3" catback for hondas.
Old Nov 11, 2007 | 07:45 PM
fin781's Avatar
Default Re: turbo/muffer? (dpetro1)
dude screw a muffler. you can run the same setup i am and hit up a 3 inch DP and have that come out the side by your door. the turbo makes the exhaust extremely quiet. at idle its throaty and deep, but at boost and driving, its not load at all, just sounds mean. screw muffler side pipe it no resornator or anything. you want be diapointed
Old Nov 11, 2007 | 08:02 PM
22psicrx's Avatar
Default Re: turbo/muffer? (fin781)
summit chamber $20 muffler 2.5" and 3" exit. I want my car real quiet and still pulled 350whp. The other car I have a Burns tit muff. really loud.
Old Nov 11, 2007 | 08:04 PM
Quickgti1.8t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fin781 &raquo;</TD></TR><TR><TD CLASS="quote">dude screw a muffler. you can run the same setup i am and hit up a 3 inch DP and have that come out the side by your door. the turbo makes the exhaust extremely quiet. at idle its throaty and deep, but at boost and driving, its not load at all, just sounds mean. screw muffler side pipe it no resornator or anything. you want be diapointed</TD></TR></TABLE>you must be crazy it will still be LOUD
Old Nov 13, 2007 | 11:37 PM
mma82's Avatar
yea thats what im getting a custom 3" exhaust with N1 muffler w/resonator. is that worse than getting a 3" exhaust system? is there a diff? how is that muffer with that custom exhaust setup? not too loud? performance good?
Old Nov 14, 2007 | 07:04 AM
fin781's Avatar
the only difference id see would be the system would typically come with a resonator, where your 3 inch setup would just be pipe then muffler. but with the exhaust going through the turbine then it really want matter.
Old Nov 14, 2007 | 12:51 PM
Bailhatch's Avatar
Maybe put two 4" round magnaflow mufflers on the long straight part and run your N1 out back. Should keep the volume pretty resonable.
Old Nov 20, 2007 | 12:43 AM
Mfoehrkolb's Avatar
Default Re: (BlackT5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackT5 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
is what i use, and my boy. these babies sound ******* dope as expletive. i rec. them to anyone.
