Electric Gremlins?
Old Nov 9, 2007 | 05:07 AM
LST2's Avatar
Default Electric Gremlins?
Ran into some weird problems yesterday. First my ignition started to cut in and out kind of like turning your key on and off, the battery light flashed and I head the fuel relay click. Then my clock stoped showing the time like it supposed to when you have the car on. The clock will show the time when I press the button next to it... it is like the clock does not realize the car is on. Then my oil light started doing strange things. It started flashing at consistent intervals. I turned the car off and then the oil light did not come on like it usually does before start up. I noticed it flash again today but only once on my drive home. Car runs fine.
Sounds like a battery or ground short somewhere, I am just not sure where to start looking.
Any ideas?
Old Nov 9, 2007 | 07:54 AM
LST2's Avatar
Default Re: Electric Gremlins? (LST2)
Strange, clock came back on during lunch.
Old Nov 9, 2007 | 02:45 PM
JaredKaragen's Avatar
if u jiggle/tap the key does it cut in and out?
lots of the time it is related to 2 things:
Defective main relay
Defective ignition switch (the plastic switch that is replacable on the column.
tab.jpb
Honda Civic (2001 - 2005)
Jun 12, 2017 01:32 PM
teerossi
16
Feb 5, 2016 06:30 PM
gsmith93
May 13, 2013 02:37 PM
JasonCRX
11
Aug 23, 2009 01:53 PM
90LSpimpin
Oct 6, 2004 10:06 PM
