block gridle question help
Old Nov 17, 2007 | 03:02 PM
laziebun's Avatar
Default block gridle question help
can i use a gridle from one GSR to another GSR block? i heard that i need to use the same gridle that came on that block no mis matching should be done with the mains and the gridle. Is that true will i mess somthing up if i dont use the same gridle on the same block?????
Old Nov 18, 2007 | 05:35 PM
laziebun's Avatar
anyone please???
Old Nov 19, 2007 | 10:31 AM
DA_HONDA_BOY's Avatar
Default Re: (laziebun)
yes u can it's all the same and you can use them in ls,b20 and b16
Old Nov 19, 2007 | 10:34 AM
Default Re: (DA_HONDA_BOY)
and if you use them in ls,b20 or b16 you must gsr main caps & gridle and main studs
Old Nov 19, 2007 | 12:53 PM
CerealKiller's Avatar
Default Re: block gridle question help (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">can i use a gridle from one GSR to another GSR block? i heard that i need to use the same gridle that came on that block no mis matching should be done with the mains and the gridle. Is that true will i mess somthing up if i dont use the same gridle on the same block?????</TD></TR></TABLE>
You can use them, BUT you better do a line hone.
delsol8017
Dec 20, 2008 10:35 AM
pogeeboy27
Paint and Body
Mar 6, 2008 11:34 AM
FUPAH8TR
Oct 3, 2007 08:04 PM
b16a4
25
Jul 16, 2007 08:15 AM
X2BOARD
Apr 29, 2002 07:41 AM
