440cc precision injectors dont fir d-series?
440cc precision injectors dont fit d-series manifold?
Anyone else here got precision injectors that dont fit d-series manifold? The injectors are marked with 0370. The metal tip thats going into the manifold is measuring 12mm, and the manifold about 11.3mm. Thinking about just taking off the manifold an drilling up the holes to about 12.5mm. Has anyone else tried this?
Re: 440cc precision injectors dont fit d-series manifold? (YiNYaNg)
The <U>metal</U> tip on the injector is 12 mm, and the hole in the manifold is 11.3. Dont think muscles will do it
Anyway, I took off the manifold and machined them up to 13mm. Should do the trick
Re: 440cc precision injectors dont fit d-series manifold? (mtber)
Its a 94 D16Z9 (similar to D16Z6), engine is from Germany. Maybe some EDM issue, I dont know. There was no way they would fit before I modified the manifold.
something different
1 Post
Re: 440cc precision injectors dont fit d-series manifold? (steinar)
my buddy had that problem on a JRSC manifold (smaller hole than his stock ITR manifold)..
those injectors have a BIG tip.
