turbo question
Old Nov 18, 2007 | 08:55 AM
b18 hatch mike's Avatar
Default turbo question
if you have a gsr stock block then put a b16 head on it that will mae it better for turbo cuz the head flows better and has lower compression than a gsr head right
Old Nov 18, 2007 | 09:05 AM
Schister66's Avatar
Man U FTW
The b16 head does not flow any better than the GSR head...the only reason people swap the B16 head onto a GSR block is because it raises the compression IIRC and makes a "Poor Man's ITR." If you're going to boost, just keep the GSR as is and have fun...
Old Nov 18, 2007 | 09:14 AM
Default Re: (Schister66)
ok but i have always been told that it flows better even on here thanks thought
Old Nov 18, 2007 | 09:20 AM
Schister66's Avatar
Man U FTW
A while back there was a flow bench test of the two heads compared against one another. The GSR actually flows more air in the mid range and barely loses out up top. Either way a GSR block/B16 head is going to be less than ideal for boost...
Old Nov 18, 2007 | 09:33 AM
well that sucks cuz i sold my gsr head now i have a b16 head and a gsr block and a urbo kit lol to put on it should be fine with a good tune
Old Nov 18, 2007 | 09:48 AM
Schister66's Avatar
Man U FTW
It should be fine with a good tune; however, dont expect crazy things out of it with such high compression...
Old Nov 18, 2007 | 10:09 AM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">The b16 head does not flow any better than the GSR head...the only reason people swap the B16 head onto a GSR block is because it raises the compression IIRC and makes a "Poor Man's ITR." If you're going to boost, just keep the GSR as is and have fun...</TD></TR></TABLE>
It actually lowers compression switching from a GSR to B16 head about .2 points.
Old Nov 18, 2007 | 10:17 AM
Schister66's Avatar
Man U FTW
Default Re: (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
It actually lowers compression switching from a GSR to B16 head about .2 points.</TD></TR></TABLE>
I'll never claim to be a hybrid guy, but i thought that the GSR block/B16 head was a high compression setup....hmm
Old Nov 18, 2007 | 11:15 AM
yeah i thought it lowered it
Old Dec 15, 2007 | 12:31 PM
patriot's Avatar
Default Re: (b18 hatch mike)
yeah, lowers it. the combustion chambers in the b16 head are larger than the gsr's
EgxHaTcHxGsR
Nov 22, 2009 10:51 PM
j me4door
Mar 10, 2009 12:31 PM
xxnuttybarxx
Oct 25, 2007 01:04 PM
BI8B
Sep 11, 2003 08:38 AM
CBR
Aug 19, 2002 07:18 AM
