Turbo gasoline
Old Nov 17, 2007 | 11:26 AM
Shaynepolevault's Avatar
Default Turbo gasoline
if i turbo my car i have to use 91 octane correct? im kind of new and i'm not 100% sure of this, I will be doing a turbo build in the next week so just was wondering!
Old Nov 17, 2007 | 11:30 AM
Schister66's Avatar
Man U FTW
You can tune on whatever fuel you like, BUT the higher the octane, the more power you can make. Higher octane fuels resist detonation better than lower grade fuel and can therefore support more boost, higher intake temps or higher compression.
Old Nov 17, 2007 | 11:31 AM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">You can tune on whatever fuel you like, BUT the higher the octane, the more power you can make. </TD></TR></TABLE>
so if i used lower fuel to tune and then i decided to go with 91 would that mess anything up or would i lose power? and if i tuned on like 87 will my turbo not last as long or something?
Old Nov 17, 2007 | 11:36 AM
Schister66's Avatar
Man U FTW
Default Re: (Shaynepolevault)
Tuning on 87 is not really a good idea and depending on what engine you have, may not be possible. GSR's (and i'm sure B16's) have a knock sensor built into the block. Simply running less than a 91octane on stock will cause them to knock. The ECU will drop timing off and your car will run like hell.
For the extra pennies per gallon, its worth your time and money to tune on the highest grade (other than race fuel) you can get at the pump. Look at it this way: you already put all kinds of money into a turbo setup, why cheap out on $.15/gal to run 87 vs 91-93?
Old Nov 17, 2007 | 01:00 PM
melovesboost's Avatar
dont forget the cheap E85
Old Nov 17, 2007 | 01:40 PM
Schister66's Avatar
Man U FTW
Default Re: (melovesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost &raquo;</TD></TR><TR><TD CLASS="quote">dont forget the cheap E85 </TD></TR></TABLE>
that's my next tune...there is so much potential in E85 and its CHEAP!! The only problem with it is that it isn't available everywhere
Old Nov 17, 2007 | 03:31 PM
Tippyman's Avatar
that's my next tune...there is so much potential in E85 and its CHEAP!! The only problem with it is that it isn't available everywhere</TD></TR></TABLE>
i want it near me so bad...
I'd tune with it in a heartbeat!
Old Nov 17, 2007 | 03:43 PM
roachsboosted16's Avatar
Default Re: Turbo gasoline (Shaynepolevault)
usually wen u turbo u go with 91, but if ur runnin say 2psi u cude probly settl for regular
Old Nov 17, 2007 | 04:20 PM
Schister66's Avatar
Man U FTW
Default Re: Turbo gasoline (roachsboosted16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
I'd tune with it in a heartbeat!</TD></TR></TABLE>
I wish i would have...before i started my first setup (3 years ago) i asked around and everyone told me that it was impossible to tune w/ it. Now its all the rage. Up here in ND its at about half the fuel stations...come spring, i think i'm going to tune on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">usually wen u turbo u go with 91, but if ur runnin say 2psi u cude probly settl for regular</TD></TR></TABLE>
If you're running 2psi, sell your turbo setup and go buy NAWZ stickers. They'll do about as much good...
Old Nov 17, 2007 | 05:07 PM
m R g S r's Avatar
e85 ftw
turboeagle4g63
Jan 4, 2010 01:27 PM
eg:R
Nov 27, 2007 06:15 PM
bmanuhutu
Nov 2, 2006 01:52 PM
racekar
May 1, 2005 04:06 PM
nd8ch
Apr 15, 2003 07:42 AM
