Thinking about a rebuild - Comments? Recommendations?
Old Nov 10, 2007 | 03:40 PM
Jamarquis's Avatar
Default Thinking about a rebuild - Comments? Recommendations?
Well I'm leaking oil at an alarming rate and loosing compression so I'm planning on rebuilding my motor. While I don't have a lot of extra cash to boost it right now, I would like to at some point down the road. (maybe next fall) but I need my car to be drivable now. My plan is to go right through the bottom end. Getting the block honed out, new pistons, rings, rods, main bearings, gaskets ect...
My plan is to build the bottom end to handle higher boost levels while keeping compression and displacement as close to stock so I don't have to get retuned right away. I had thought about going all motor but boost is more fun and All motor would cost me more all around...
I have a B16A3. Comments? Recommendations?
Thanks
Old Nov 10, 2007 | 03:43 PM
DeadVet's Avatar
Default Re: Thinking about a rebuild - Comments? Recommendations? (Jamarquis)
Where are you leaking oil from? What do you mean by, you are losing compression?
What are your goals for this build? That would help to determine what you need to do.
Old Nov 10, 2007 | 03:59 PM
Jamarquis's Avatar
Default Re: Thinking about a rebuild - Comments? Recommendations? (1TurboHatch)
I'm burning oil and have one cyl with low compression...I believe the piston rings are gone in that cyl. the car is still drivable, but would like to get things fixed before things get worse...I'm in the planning stages of this rebuild. I hope to do it this coming spring...
My initial goal is to stop the leaking and rebuild an engine with 210k miles on it. without having to get the engine tuned.
My longer term goal is boost and have a really fun daily driver. (250hp or so)
My budget only allows for one to happen at a time...hence the rebuild
Old Nov 10, 2007 | 05:53 PM
blkb18's Avatar
If your planning for high boost your not going to be able to maintain your factory compression.
Old Nov 10, 2007 | 06:42 PM
reboosted's Avatar
Default Re: Thinking about a rebuild - Comments? Recommendations? (blkb18)
had the same problem, turned out that i needed to retighten the head. the oil was comming out due to a couple loose head studs
Old Nov 11, 2007 | 06:36 PM
Jamarquis's Avatar
Old Nov 11, 2007 | 07:43 PM
reboosted's Avatar
do you have a 2nd car while you rebuild
Old Nov 12, 2007 | 06:35 PM
Jamarquis's Avatar
Default Re: Thinking about a rebuild - Comments? Recommendations? (reboosted)
I'm in the Planning stages right now...I'm moving in the spring right down the road from work...I'll be an enviromentally freindly commuter for a bit...IE Peddle bike...when I'm actually doing the rebuild. I bought a house a while back and neglected my car...so now that I'm selling the house...She's getting more attention again...
central_driver
Jul 28, 2010 11:30 AM
shermanyang
May 28, 2008 12:26 AM
SOHC_MShue
Jan 16, 2007 04:21 AM
bdpetska
Jul 18, 2006 04:12 PM
Mr. Vapor
May 28, 2005 11:28 PM
