AEM EMS question...
Old Nov 13, 2007 | 03:45 PM
wade's Avatar
Default AEM EMS question...
Thinking about picking up an AEM EMS. I hear they like to destroy stock honda ignitors or coils, forget which. Is that true?
Old Nov 13, 2007 | 04:20 PM
wHOAlly's Avatar
Default Re: AEM EMS question... (wade)
neither as long as the proper dwell settings are used.
although, when u throw the MSD into the mix, the ignitors and built in AEM EMS ignitors have been known to fail. but, when u throw an MSD onto a stock ecu u will get ignitor failures too.
seems to be a hit and miss, my digital 6 and hondata'd ecu never killed an ignitor
Old Nov 13, 2007 | 04:38 PM
Newt Dog's Avatar
Default Re: AEM EMS question... (wHOAlly)
I believe the msd and the aem ems use different frequency's. I blew my coil driver in the ems and went through 2 ignitors. I then realized it was the msd box. I'm running the stock ignition system with the aem ems now with no problems.
Old Nov 13, 2007 | 04:46 PM
Jared's Avatar
Default Re: AEM EMS question... (Newt Dog)
I've run several MSD boxes directly from the AEM bypassing the ignitors as well as multiple stock ignition setups without issue. I think some of the older boxes had too much coil dwell in the base maps.
Old Nov 13, 2007 | 04:59 PM
Newt Dog's Avatar
Default Re: AEM EMS question... (Jared)
10-3000. You hit that on the money!
Old Nov 13, 2007 | 06:28 PM
wade's Avatar
10-3000 what about it?
Old Nov 13, 2007 | 06:40 PM
boosted hybrid's Avatar
Just bypass the ignitor. Use a digital msd box and proper coil, and just wire the white wire on the msd to the coil#1 output from the AEM box. Set coil dwell to "All CDI Systems", and your set. If you are using a T1 cam trigger kit make sure you use the updated coil dwell factor and dwell max settings specified in the instructions or you'll have misfiring above 7.5k+.
Old Nov 13, 2007 | 06:42 PM
wade's Avatar
Default Re: AEM EMS question... (boosted hybrid)
thanks jeff. how ya been? long time no see... ahh the married LIFE!!!
Old Nov 13, 2007 | 06:47 PM
Everything is good, just busy around the shop like usual.
bzyq2001
May 12, 2011 06:40 AM
VtecSleeper
Oct 26, 2007 01:55 PM
AllMotorRandy
Mar 23, 2006 01:25 PM
shermanyang
Sep 15, 2004 05:49 PM
