Replacement(upgraded) turbo manifold for greddy turbo kit with TDO5 18G
I want to upgrade the log style manifold on my greddy equiped turboed gsr. Looking for tubular manifold that would bolt on.
What are my options?
Re: Replacement(upgraded) turbo manifold for greddy turbo kit with TDO5 18G (jfboy)
not for bseries, but im sure he can make one
http://www.homemadeturbo.com/f...052.0
Re: Replacement(upgraded) turbo manifold for greddy turbo kit with TDO5 18G (akira712)
yeah I'm sure he could but I want one that is already built so I dont have to leave my mani with them for a long time. I drive my car everyday.
I don't think there are any out there that are 'shelf' manifolds. Personally, I would ditch the set-up and go with a new manifold, turbo, wastgate, and dp.
i think you should ;eave the setup alone and have the turbo upgraded...especially when you;re able to keep the a/c....on a greddy kit you're capable of 300 whp
Re: (BR0KENB20)
The gains will be minimal if you just replace the manifold since its design isnt too bad for a cast manifold. The main issue when looking for more power with the Greddy kit is the turbine outlet + downpipe.
If you are looking for over 300whp then you are better off just selling the Greddy kit and getting a new turbo, downpipe, manifold that will meet your goals.
Re: Replacement(upgraded) turbo manifold for greddy turbo kit with TDO5 18G (RCautoworks)
I think if you maxed the system out it would make more power than most think. I believe lovefab used to make a ramhorn with that flange as an option. I say get a ramhorn mani, weld the stock gate shut and get an external 38mm gate and you will make not only more power but also have a better powerband
PS- I made 309whp 242wtq on 17psi with that turbo and greddy mani and piping tuned on hondata and 94 octane
maxoutracer
08-02-2005 05:41 PM
